Do I need to replace my EBCM?
Old Dec 23, 2022 | 09:18 AM
Idunnowmyname's Avatar
Idunnowmyname
Default Do I need to replace my EBCM?
Hey all! New Corvette owner here! 2006 coupe 6 speed manual.
I bought the car with the ABS and TC lights and the service and/tc/ah messages displaying on the dic.
I removed the electric side of the EBCM, checked for voltage and ground on the harness at the applicable pins. Both were okay. I thought I found the problem (bad connection on black plastic bridge connector) and re assembled it but nope! Lights all still on.
I had it scanned and have the following codes.
C0121
C0899
C0110
C0252
Can I accurately diagnose this without a Tech 2? Any help is greatly appreciated. I am willing to replace the EBCM but I want to have a concrete diagnosis before throwing parts at the car.
thank you In advance!
Hydraulic Pump Half of EBCM
Old Dec 25, 2022 | 09:59 PM
GMJim's Avatar
GMJim
Usually caused by cold solder joints on the board. Make sure your battery voltage is up. If you can't solve it try absfixer.com
