Harmonic balancer help asap!
Old Dec 26, 2022 | 08:04 PM
C3Angel's Avatar
C3Angel
Default Harmonic balancer help asap!
So I am looking at installation of many harmonic balancers and noticed the Klowny video on YouTube. He used this “Friction Washer” at the end of the Harmonic balancer.
my question is if I need this washer at all for the install as I have noticed I cannot find the same washer besides that one I have posted.
thank you, and have a great day!
Old Dec 26, 2022 | 09:41 PM
russ472's Avatar
russ472
its gets sandwiched in between the balancer and the lower timing chain gear. it probably stayed on the crankshaft when you took the balancer off.
Old Dec 26, 2022 | 10:00 PM
davidfarmer's Avatar
davidfarmer
Those came out in approx 2010, wasn’t oem at least on early c6’s.
I’ve never used one, but I pin my cranks . Good insurance but i bet few cars have them
Old Dec 26, 2022 | 11:18 PM
C3Angel's Avatar
C3Angel
So I’m good on not using it and replacing with just the ARP bolt, Summit Harmonic Bal., new belts, and new GM timing chain seal?
Old Dec 27, 2022 | 04:00 AM
torquetube's Avatar
torquetube
No, the diamond washer was added during the first year of production (MY2005) to address loose balancers. Symptomatic customer cars got the washer retrofitted under a TSB.
My 2006 came with the washer from the factory. All the cars got them.
I would use the washer. There isn't anything in principle that makes it less necessary with an ARP bolt or a Summit balancer.
The only thing that would change would be keying/pinning the crank.
Note there's a new-style washer that comes without the rubber retainer. It just looks like a circular shim with a single keyway notch. Works the same way as the original.
Old Dec 27, 2022 | 12:22 PM
mcm95403's Avatar
mcm95403
Interesting, looks like one more thing I need to buy for my project............
Old Dec 30, 2022 | 03:39 PM
schizcat's Avatar
schizcat
The washer is only needed on OEM balancers. Aftermarket does not require it.
To Harmonic balancer help asap!
