Tie Rod Problem
Old Jan 13, 2023 | 03:02 PM
1955retiree's Avatar
1955retiree
Default Tie Rod Problem
I am having a problem removing front tie rod . It got bent hitting a curb. I cannot figure out how to remove the clamp on the boot on the inner rod without messing it up. Is there some trick to getting clamp off? It's not the easiest to get to. Thanks in advance.
Old Jan 15, 2023 | 09:59 AM
AgainstTheWind's Avatar
AgainstTheWind
If I recall there is a notch on the clamp that fits a flat head screwdriver and you twist it open
Old Jan 15, 2023 | 05:06 PM
1955retiree
Thanks. Finally got it off.
To Tie Rod Problem
