No power to either door
Old Feb 4, 2023 | 01:40 PM
eisworthr's Avatar
eisworthr
Default No power to either door
I have a 05 c6 and now it has done this twice. Just random with no common reason that i found. Both doors lose all functionality, cant open door from inside or out beside the manual handle. No windows or door locks function. every other function in the car works when this happens as far as i know. I havent had it happen when i am able to check anything with a multimeter or anything but it just does it randomly and then will start working again after a little bit. any ideas??
Old Feb 4, 2023 | 05:43 PM
sleepingcougar's Avatar
sleepingcougar
There is one fuse for the door locks and one for the door switch. please check them first.
Old Feb 4, 2023 | 06:19 PM
eisworthr's Avatar
eisworthr
the fuses are good and they all stop working at the same time and all start back working at the same time so shouldn’t be a fuse
Old Feb 5, 2023 | 10:48 AM
pcguy2u's Avatar
pcguy2u
In which panel are the fuses located. You may have to check the source of power to those fuses on the permanent wiring side of the respective panel(s). If/when you do that, be aware that if the problem is what I refer to above, the issue may be an intermittent connection that will somehow fix itself in the process; something that no one who is trouble shooting a wiring issue wants to hear. So look very carefully.
Good luck, Nick
To No power to either door
