Has anyone had their NPP stay open and it was not the solenoid in the bumper causing the issue? I know there is a module over the rear passenger tire in the cargo area, but so far the solenoid did not solve the issue of the valves staying open. I still have to dig into it and apply vacuum to the actuators and all the other odds and ends to trouble shoot it. Just curious.
Mine was opposite (staying closed 100% of the time) but it was the solenoid...I couldn’t even blow thru it. Hate to state the obvious, but are you blowing fuses? I was blowing fuses every second too.
Ya, fuse is good, which it was that easy.
Originally Posted by vetteish
1 more thing...when my battery is weak it wreaks havoc on my M2W. As we know a weak battery and a C6 is not a good combo
New battery and its always on a battery tender. Once I get the car out of storage and up in the air I can start checking to see if im getting vacuum to the actuators and apply vacuum to them to see if they close. Just curious what everyone else has run into.
Definitely check the vacuum. When I bought my JSB ZR1 the NPP was staying open all the time. Turned out the vacuum hose had popped off at the valve. I popped it back on and that was that.
not yet. Cant move the car to get it in the air because I dont have any seats in it (sent them to caravaggio). Once I figure out what the problem is, ill post what I find
I was about to change the solenoid on mine (wasn't getting vacuum), and by mistake dropped it (fumble fingers). Heard a click and it started working again. Never a problem again. If all else is no good, maybe just try tapping it lightly to see if it isn't stuck.
Good luck with the Caravaggio seats...love mine
I already replaced the solenoid and no luck. Hopefully its something simple; through all the searching of posts, I haven't heard of any crazy stories that caused the exhaust to fail other than the basics. Ya, cant wait for my seats! My old ones just arrived at Caravaggio yesterday so now I'm getting really pumped.
Just to bump my thread, figured it out. Applied vacuum with a mightvac hand pump to the mufflers and they closed. Then I worked my way forward and disconnected the line from the back of the intake manifold that connects to the nipple going back to the mufflers right by the firewall. Applied vacuum and sure as **** the flaps closed. Was just feeling my way around to see if somehow the line came disconnected from the back of the intake and somehow the rubber line right near the connection to the nipple (I dont know what else to call that connection) was rubbing against probably the braided fuel line and it made a hole in the line. Cut the section out and reconnected everything and everything is good!!!!!
I had mine stay open last year. I replaced the solenoid behind the bumper and put fresh batteries in the M2W remote. Problem solved and been working perfectly since.
that was my dilemma when started this thread, replacing the solenoid did not solve my problem. Just glad I was able to fix this, I hate having the flaps open pulling into my house and being a dick to my neighbors with how loud this car is.
