What does a catch can catch?
Old Feb 20, 2023 | 02:23 PM
SpinMonster's Avatar
SpinMonster
Far better than arguing about politics or religion with the same results; In the end no one changes their mind.
Old Feb 20, 2023 | 04:00 PM
BadAV's Avatar
BadAV
You have commented twice in the thread now without giving YOUR opinion. What is it?
Old Feb 21, 2023 | 02:04 PM
SpinMonster
Catch cans only catch a small portion of the oil but I still don't want to have more oil go in. I've seen cars at 200k miles with and without catch cans so it doesn't hurt either way. Crazy power has been made with a catch can so it isn't hurting the engine to have it. Having ported 100's of manifolds, I can always tell who runs a catch can and who doesn't.
There is nothing I've typed here that I haven't typed before on the many threads on this topic over the years. People rarely change their mind so I don't get involved with the threads and they tend to get locked and disappear. Politics, religion, and catch cans.
Old Feb 21, 2023 | 06:00 PM
BadAV's Avatar
BadAV
Appreciate the response; I don't remember seeing your thoughts before.
Old Feb 21, 2023 | 06:24 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
In may case, I chose to install a catch can because I have a Magnuson 'Heartbeat' PD style supercharger, and I just don't want oil entering and 'gunking' up the supercharger's rotors and charge-air coolers.
Old Feb 21, 2023 | 07:03 PM
Aardwolf's Avatar
Aardwolf
You can tell who does and doesn’t because the valves are dirty or?
Old Feb 21, 2023 | 11:04 PM
Kingtal0n's Avatar
Kingtal0n
Because people copy each other. Because catch cans don't decrease engine power, so it still looks like a good idea.
That is the main argument I encounter: " I added a catch can and the engine didn't lose any power, so why not use one?"
I never said catch cans reduce power. I typed a whole lot of **** but that wasn't one of them.
I only pointed out that catch cans will ruin the engine. That they make increase oil aspiration to the cylinder. That they will cause deposits and lead to eventual engine failure.
You can make more power by disabling the PCV system and simply running a breather- Why? Because crankcase gas dilutes intake charge with spend vapors like CO2 and H2O that are useless to the engine. PCV isn't an engine power increaser, it is an engine longevity and lifespan increaser.
I'll give you two quotes or excerpts from an engineer and tuning literature 'guru'
Lots of people are also wrong about PCV needs with sustained boost. Follow the steps above to properly evacuate the crankcase using either manifold vacuum or compressor inlet depression at all times.
If you are building crankcase pressure (from blowby on the power stroke without proper evacuation), this pressure can also go the other way past the rings during the intake stroke. You can get oil ingestion to the cylinder past the rings without ever going trough the traditional PCV route (intake system).
-Greg Banish
-Calibrated Success, Inc.
From this thread
https://www.corvetteforum.com/forums...post1606134728
And literature by our retired 'boost engineer'
https://www.theturboforums.com/info/...rs-101.378656/
...almost no evacuation to remove the contaminant laden vapors from the crankcase and this allows them time to settle and mix with the engine oil accelerating wear and eventual failure. So it is critical to use a system that provides full time evacuation suction.
you would never want to use a can with a breather on it, as that is breaking the evacuation cycle leaving the contaminants in the crankcase, and also allows pressure to build and be pushed out which is never proper. That technology went out with the 1980's.
The information is embedded within the understanding that, if you do not measure and set the crankcase pressure to a negative number, it doesn't matter what type of system you have or think you have, it might not be working as intended to remove contaminants which leads to deposits and eventual failure.
If we install a tire we check the tire pressure. If we modify the fuel system we check the fuel pressure. If you've altered the oil pump/system you check the oil pressure. You may also be aware of coolant pressure. If you modify the intake system add forced induction you measure the boost pressure. And so forth.
All of these systems have a pressure value associated to them. They all must be measured when performing modifications. For example you would never put on a new tire or new fuel regulator without measuring and setting the fuel or tire pressure. Imagine the consequences of doing something so foolish.
Well the same situation applies to the crankcase pressure. You modify the engine, the PCV system, the air filter (air filter is part of PCV system), you MUST MEASURE the crankcase pressure and set the crankcase pressure properly. Otherwise... consequences (read above quotes)
Old Feb 23, 2023 | 07:27 AM
DAIZY502's Avatar
DAIZY502
Originally Posted by wjnjr
Here's what it caught. The liquids separated into different layers after a while.
I have had a catch can contents look just like that. I had just installed a brand new engine. There was a head gasket issue leaking a little coolant into the oil. Once that was resolved, the contents of my catch can have looked like "oil".
Old Feb 23, 2023 | 11:31 AM
SpinMonster
Because of the amount of oil in the intake manifold that, at times, literally drips out. Manifolds from cars with a catch can don't have this.
Old Feb 23, 2023 | 12:50 PM
Aardwolf's Avatar
Aardwolf
That's what I've seen too and on some it bakes on.
Old Feb 23, 2023 | 03:59 PM
VetteVinnie's Avatar
VetteVinnie
A catch can can catch what a catch can can when a catch can can catch catch.
Sorry, had to do it.
