Intakemanifold
Old Mar 8, 2023 | 05:48 PM
Blackvettez51's Avatar
Blackvettez51
8th Gear
Default Intakemanifold
Dose anyone know if OEM intakemanifold #12590124 will fit a 2010 base modle 6.2 vette, im new on here an dont know how to get around much.
Old Mar 9, 2023 | 11:16 PM
Supturbo's Avatar
Supturbo
Yes and no
I have the l76 (12590124) intake on my ls2/ls3 top and although it fits the ls3 or 6.2 heads the map sensor hole had to be drilled out slightly. The ls2 or 6.0 map fits perfect but would need a ls3- ls2 harness and a tune as the table is slightly off between the 2 maps.
Old Mar 10, 2023 | 09:19 AM
Blackvettez51
8th Gear
Thank you so much, i will be putting ls3 top on my ls2, an i have that intakemanifold good to know that its gunna work.
Old Mar 10, 2023 | 09:20 AM
old motorhead's Avatar
old motorhead
If you want an intake manifold that works with your Vette, buy one that came from a Vette with an LS3. Less headaches and you'll know it works.
Old Mar 10, 2023 | 10:36 AM
Blackvettez51
8th Gear
So if i use my ls2 map sensor in the ls3 intake i wont need ad adapter, 2005 vette
Old Mar 10, 2023 | 10:52 AM
old motorhead
Thought you were dealing with a 2010 Vette. Makes sense now.
Old Mar 10, 2023 | 04:32 PM
Blackvettez51
8th Gear
The ls3 heads i have came off a 2010 vette thats why i was asking if # 12590124 intakemanifold would fit, my car is a 2005 z51 ls2 im gathering ls3 parts an some day im going to put the ls3 top on it, looks like an easy way to get 550 hp, with cam,headers, cai an a tune, my car has the z06 wide body on it, manual, convertable, love it, ty for your help brother.
Old Mar 10, 2023 | 05:05 PM
old motorhead
550 engine HP isn't too difficult to do. 550 rear wheel HP is a pretty tough nut to crack without a big cam, expensive heads, high CR, high dollar intake manifold, etc.
Old Mar 10, 2023 | 05:55 PM
Blackvettez51
8th Gear
Yes i was talking crank hp, im shooting for about 480 rwhp, looks pretty easy with the awesome ls3 top
Old Mar 10, 2023 | 05:56 PM
Blackvettez51
8th Gear
Allso should i just use my ls2 map sensor, or do i need something else ??
Old Mar 11, 2023 | 09:01 AM
Supturbo's Avatar
Supturbo
Use your stock ls2 map it will plug right in just like the ls2 intake.
if you go ls3 intake then you will need a different map and an adapter harness as the ls2 and ls3 are wired slightly different.
Old Mar 11, 2023 | 09:55 AM
Blackvettez51
8th Gear
Ive read that theres no sents in using a ls3 or any map sensor that is greater then 2.5 bar because the ls2 has the ecm e40, an cant take advantage of any thing higher, i read ells were that my ls2 map is ok to use, if i was going super change i would probley need something different., im just gunna use my ls2 stuff, i think ill be ok, thanks for your info.
To Intakemanifold
