Vibration at 80+ mph
Old Apr 16, 2023 | 01:58 PM
Richi's Avatar
Richi
Default Vibration at 80+ mph
Hi,
Car is a 2005 C6 Z51
I have a lot of vibrations past 80mph and it gets worst at higher speed.
Tires are brand new and got the problem before changing them.
What would I need to check ?
Thanks for your help
Richard
Old Apr 16, 2023 | 04:25 PM
0-60C6's Avatar
0-60C6
Originally Posted by Richi
Hi,
Richard
If they’re brand new tires, all I could think of are lugnuts not correctly tightened, tires could be defective, or most likely you just need them re-balanced.
Edit: if you’ve had this problem even before changing the tires, check that your rims arnt bent. I’ve had the same problem and new gumby style rims and PS4s fixed that.
Old Apr 16, 2023 | 04:46 PM
ClothSeats's Avatar
ClothSeats
Take it to a shop with a chassis dyno.
Old Apr 16, 2023 | 07:26 PM
Richi's Avatar
Richi
Beside the rims, could it be something else like brake rotors, shocks or something else ?
Old Apr 17, 2023 | 11:55 AM
Shzfast's Avatar
Shzfast
Is the vibration in the front, the back or does it seem to be the whole car? Vibration could come from all the aforementioned above but if you had the problem before the new tires and new tires didn't solve the problem, then continuing to mess with the tires isn't the answer. It could be bad wheel bearings, motor mounts, harmonic balancer, torque tube/driveshaft couplers or a combination of these things. Bad shocks will not cause a vibation and warped rotors will not typically cause a vibration until you actually hit the brakes but then the steering wheel will shake which is the giveaway that it's the rotors. I had an experience where some bad tie rods caused a vibration, so it could be a lot of different things, which is why vibrations suck. Be systematic about it and eliminate one thing at a time but try not to just throw parts at it. I hope this helps.
Old Apr 17, 2023 | 03:29 PM
vetteJPJ's Avatar
vetteJPJ
Have you had the alignment done recently?
Old Apr 17, 2023 | 07:09 PM
wjnjr's Avatar
wjnjr
Old Apr 17, 2023 | 08:34 PM
Spaceme1117's Avatar
Spaceme1117
Originally Posted by wjnjr
If I had a nickel every time this has happened to me.
Also, where the hell would someone get "DOT 3 Insecticide".
Old Apr 18, 2023 | 11:59 AM
Richi's Avatar
Richi
I will check all those points thanks
The vibration seems to be located at the front of the car
Can't be the HB I changed it 2 years ago for an ATI
Old Apr 18, 2023 | 12:00 PM
Richi's Avatar
Richi
Not recently but I can do it for free so I will give it a try
I will go to a different shop to be sure
Old Apr 18, 2023 | 04:21 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
This might be pretty basic, but make sure the wheel stud retaining clips have been removed from all wheels. If any are in place, they will prevent the wheel from seating fully & cause vibration regardless of wheel balancing.
Old Apr 18, 2023 | 07:38 PM
old motorhead's Avatar
old motorhead
I had a similar thing happen to me. Everything was A OK until high speeds. Turns out that my powder coater warped my wheels during the powder coating process. Fronts were really bad and the rears were just semi bad. New set of wheels cured the problem. Although expensive, the cure was pretty simple.
Old Apr 18, 2023 | 07:57 PM
Richi's Avatar
Richi
Originally Posted by Discount Tire
@Richi Discount Tire store locations have the ability to road force balance your tires. If it is in fact a tire/wheel problem, they would be able to get you taken care of.
I live in Martinique
Old Apr 18, 2023 | 08:07 PM
Richi's Avatar
Richi
I will start with an alignment and wheel balance.
Will keep you in touch
Old Apr 20, 2023 | 11:55 AM
Kevin Mason's Avatar
Kevin Mason
I had a bent rim cause high speed vibration/shaking on my '69 Vette.
Old Apr 20, 2023 | 05:51 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Yeah. Like every small town has one of those.
Tom
Old Apr 20, 2023 | 05:53 PM
Richi's Avatar
Richi
Tom
To be honest I couldn't tell you what the french translation for a chassis dyno is.
Old Apr 20, 2023 | 05:58 PM
TCW's Avatar
TCW
Here in the South its called a Chassis Dyno.
Tom
To Vibration at 80+ mph
