push button start don't work
Old May 30, 2023 | 03:53 PM
keith ragan's Avatar
keith ragan
Default push button start don't work
2005 base coupe, it will not crank when the button is pushed, however, if I get out and put a jumper wire in the crank trigger relay it will crank and start right up and runs great. Anyone have this issue before?
Old May 30, 2023 | 05:56 PM
Dano523's Avatar
Dano523
Need more information, hence if you are getting any warnings in the DCI.
The low down, is when you press the start button, BCM checks to make sure that RCDLR is picking up the fob in the car via 2 of the antennas, check to make sure that auto trans in park and you have your foot on the brake/manual trans has you pushing the clutch pedal all the way down, and once these are meet, will send the run comand to the ecm and use the run/crank relay on the bottom of the BCM to crank the starter for either 5 seconds or until the motor starts.
So on that note, put a tech II on the car, to make sure that the BCM is first getting the starter button signal, the needed other conditions have been meet for the trans type, and that its sending the crank signal (all of these can be check in BCM data), and the crank/run relay on the bottom of the BCM is fine
If getting no fob found in DIC, then RCDLR is not picking up the Fob via two antena's to prove that its in the car cabin (only one antenna has to pick up the fob for you to get into the car.
The fact that you can jump the starter relay to start it, means that the BCM is sending the run signal to the ecm, so its the other conditions and the run crank Relay that you may want to check on the bottom of the BCM (have to remove the BCM from the car to get to the bottom of it for that relay).
Old May 30, 2023 | 06:55 PM
keith ragan
I cleaned the battery connections and it did start by the button a few times. Looks like the battery cables are bad as see some corrosion on them. Gonna try new cables and the battery is 5 years old so it may not be up to snuff as well since the car was not used much in the last year. Do you have a diagnostic reader that you would recommend? Thanks for your replies, I have built a lot of C2 corvettes but this is my first electronic car so lots to learn.
Old May 30, 2023 | 07:27 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If the battery is 5 years old I'd take it down to your favorite parts store and have it load tested as a weak battery may be your problem...if you then can get it started you can do a voltage drop check on your battery cables...one lead of voltmeter on battery positive and the other lead to the battery cable stud at the starter...same test on the ground side between battery negative and the battery negative block ground...anything over .5 volts is no good with the engine cranking.
To push button start don't work
