Higher stall torque converter - difficult to decide
I'm confused about this and not sure if I should spend the money to install that Yank TC or resell it at no loss because of the good price. SC3000 is mainly for supercharged application, but from what I have read from others' experiences, it works well in N.A. as well. Even 3000 stall is not an extremely high value.
As for my C6, it's a 2008 LS3 A6 and so far I only have all the known bolt-ons and a mild cam will be added in the near weeks. I will also change headers from 1 7/8 to LG 1 3/4 to get better lowend, new UD pulley, thinner Cometic head gaskets to gain compression and few other details. So the car will be modified more at the same time, and it would be convenient to include the TC in it. Just so I don't forget i already have also a 3.42 diff. from Z06 installed. I never go to the drag strip, so I don't really care about the times. I'm more interested in the subjective impressions of driving. In terms of acceleration the famous seat of the pants feeling is king for me. Will swapping from stock TC to the mentioned TC improve it or rather make it worse? Please help me to decide. Then other questions arise. What about TC efficiency? I read in a thread here that the bigger the STR number is, the lower the efficiency is at higher rpms. I'd hate to lose the power I'm carefully picking up horse by horse :-)
As long as you don't install too loose of a converter, you will be very happy how the car performs. I installed a 2,800 stall Circle-D converter in my GS and am very happy with the increase in performance and overall drivability.
You won't loose any performance at all in the high rpm range and will gain lots of performance and throttle response down low.
And since the converter still retains the lock-up feature, you will not loose any gas mileage on the highway.
I like that you're taking down the diameter of your headers, I think most people run oversized headers for their application.
I'm in the market for a LS3 vette...I will not mess around. It's getting a 4k stall. It will be 99.9% street car.
Lesson for me from my first stall is dont be scared. Stall that SOB!
If I were you I'd sell that SC and go AT LEAST SS3200
Unless you plan on locking the converter during WOT (serious drag racer), you certainly don't need to spend the extra money on a multi-clutch converter.
Just like your stock converter, a single clutch high stall converter will work perfectly for you. As you know, the converter comes out of lockup when the throttle is pressed (it will do the same with an aftermarket high stall converter unless you make changes to the car's ECM via HP Tuners.
For a street car, a multi-clutch converter is a waste of $$$
- reworked stock to approximately a 3000 stall
- SS2800
- SS3200
- SS3600
- SS4000
- SC3400
In my opinion you will be kicking yourself and ultimately disappointed if you install that converter as it'll be synonymous with installing a very small cam in that it becomes a whole lot of installation effort for very marginal gains.
One of the common complaints about going with too loose of a converter is that the car ends up feeling sloppy and you need to give the car a ton of gas just to get it rolling. With Yank however that isn't true as theirs have excellent street manners but still respond when you stomp on it. I currently have an SS4000 with stock 2.56 gears and even though it's no longer street driven, I have had the same setup in my other car and it still behaved nicely. Yes, it was a little loose because of the 2.56 gears but it wasn't "oh crap, I hate this setup".
When my race car was still a street car, I had a 3.42 Z06 differential with the SS4000 and it was super fun to drive. The advantage of higher numbered gears is that it takes up the moderate amount of looseness to make it hard to even really feel like there's a converter in the car at all (but once again, until you stomp on it).
My recommendation to you would be that if you really want the best combination of improved performance while retaining good street manners a Yank SS3600 would be your best bet.
Hope this helped.
