OnStar/Bluetooth Questions
Old Jun 16, 2023 | 12:36 PM
deedward's Avatar
deedward
Default OnStar/Bluetooth Questions
Hello All—
I just purchased a 2009 Convertible, Z51,4LT, Automatic. Neither the OnStar nor the Bluetooth are working.
I have done some checking and found that the OnStar fuse was missing so I replaced it but it didn’t help. I have checked the wiring to the mirror and antenna and it appears to be intact. The wiring to the module above the passenger footwell appears to be intact also.
My first question is does OnStar need to be functional in order for Bluetooth to work? I really don’t care if OnStar works, but I want Bluetooth to work.
If OnStar is necessary for Bluetooth to work, I’m wondering if I have either a bad mirror or a bad module.
Any ideas?
Thanks in advance for any information!
Dan
Old Jun 17, 2023 | 03:43 PM
hubes's Avatar
hubes
Both Bluetooth and onstar are controlled from the same module, and therefore run off the same fuse. If the fuse was removed, it's possible someone did it to disable onstar. Some people also remove the module. There's a way to disable onstar without disabling Bluetooth, but maybe it was done wrong. Do a search about how to disable onstar, and compare that with what your car has
Old Aug 29, 2024 | 01:22 PM
lazygoodan's Avatar
lazygoodan
Cruising
Sorry I'm seeing this over a year after the original post, but I just got my 2012 C6 Z06 this summer and I was looking for info on why my bluetooth doesn't seem to work.
In answer to deedward's post, OnStar will not work on your Corvette. I contacted OnStar and was told that my vehicle is too old. OnStar discontinued service for my vehicle when they moved to a new generation of hardware for OnStar. I was told I could not buy OnStar service for my 2012 C6.
To OnStar/Bluetooth Questions
