Am I Overpaying For This Work?
Old Jun 19, 2023 | 02:25 PM
Nick.DeConto's Avatar
Nick.DeConto
Banned Scam/Spammer
Default Am I Overpaying For This Work?
Looking to do some work on my LS3 manual C6 and am trying to see if I am overpaying as I am shoping around at different shops.
Any input would be greatly appreciated. Thanks in advance.
Old Jun 19, 2023 | 03:05 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Seems that you're searching for a "best price". IMHO, that a mistake. You should be searching for the most highly recommended & best reputation shop in your area. Anyway you cut it, you're spending big bucks & you shouldn't be "Penny wise & Pound Foolish!"
Check with your local Corvette clubs for recommendations.
Old Jun 19, 2023 | 03:45 PM
Nick.DeConto
Banned Scam/Spammer
I understand you get what you pay for and am willing to pay the right price for the right job. Just making sure that it is still reasonable and am not getting scammed/jacked price-wise.
Old Jun 19, 2023 | 05:12 PM
SixAddict's Avatar
SixAddict
That’s close to what I paid for my work. Very similar to yours except I have A6.
I agree look for the best. Buy once, cry once…..
Old Jun 19, 2023 | 05:26 PM
Dreamer2's Avatar
Dreamer2
$1,100 for headers installed?
Old Jun 19, 2023 | 05:36 PM
double06's Avatar
double06
The $1,100 is the cost of the headers? There are two labor charges - one of which is a dyno tune.
Old Jun 20, 2023 | 06:36 AM
Spaceme1117's Avatar
Spaceme1117
Why does is show replacing the manual transmission with removal and install of the engine?
If there is nothing wrong with the transmission and it is just a cam install and header install, that charge complete BS.
Rest of the charges look okay. $750 for a dyno tune is a little high but still in the ball-park.
Old Jun 20, 2023 | 12:23 PM
Dano523's Avatar
Dano523
Not seeing new lifter trays listed, so are the planing of using coupled roller lifters?
Last time I check, Johnson wants close to $1k for them, so you don't need to use the stock lifter trays.
If you are going to run with stock lifter and lifter trays, then would rethink the cam game, hence change out rocker to higher ratio to increase the valve lift that way with cam designed around them, so lifter are not being raise much higher than stock lift to not wear out the lifter trays instead. Simply, lifter trays are the only thing keeping the lifter rollers aligned with the cam lobs and if the trays wear out, will take out the lifter roller and cam lobs when a lifter does rotate.
Seeing trans being pulled, so is RPM supping a built M-6 to go back in? Also, with TT out, now is the time to rebuid it with new bearing and better couplings.
Myself, since the motor is coming out, and the top end is being torn apart, would just spend the extra few grand to have the motor completely rebuilt to bullet proof/gain more HP as well. Hence GM dropped compression on the LS3 from the LS2, and just increasing the compression makes a huge difference in the amount of HP to start with.
Myself, if motor is still good, would be looking at super charger instead of cam/higher compression. Your going to be making a lot more power , have no surging problems in slow traffic, plus not have to worry about changing valves springs every 30K as well.
Old Jun 20, 2023 | 04:15 PM
C6 Motorsports's Avatar
C6 Motorsports
How about an On3 single turbo? My bullitt had a Vortec and it was a blast but a single turbo vette is always something in the back of my mind since I acquired my c6. Cam/heads is nice but like you said, there's many downfalls for daily driving.
Old Jun 20, 2023 | 11:53 PM
sirdano's Avatar
sirdano
Dang that is the cost of a super charger and will get more HP without opening the engine. How much HP is that supposed to get?
To Am I Overpaying For This Work?
