This is going to be the stupidest thread you read today. I used to have access to a 4 post lift for previous cars but I no longer have that access. I have decided to buy 6 ton jackstands (yes I know it's overkill for a Corvette) and a 3 ton low profile jack. I"ve done dozens of oil changes on the lift, but never in my life have I used jackstands and a jack. Any major dos and donts I should be aware of? The thought of getting under the car on jack stands is a little disconcerting but I know guys do it every day. I'll be doing this for my C6 and 2 Camrys.
ETA....I already have jacking pucks
The six ton is useful. If you lift one side of the Corvette at the front puck to your jack's full reach, then put the jack stand where the suspension connects to the cross frame, when you lower the jack, that sde will come down and the other side will go up -- both front wheels will be off the ground. So 1 6 tons isn't overkill. I did this recently when replacing a clutch master cylinder.
I have used jacks and stands and ramps for the past 40+ years. If you are concerned about relying on stands, give the car a good shake before going under. Or better, let it sit on the stands overnight. In my opinion, the danger is not that a stand will fail. I think that the greater danger is that you might tip one over in your process. I do prefer ramps for oil changes and such. And, no reason that you can't use stands and ramps in most cases.
I am under my HPDE car often. I place jack stands at the preferred vehicle jacking locations listed above. I place a short section of 2 x 4 between the jack stands and the frame.
I double up, by placing cement blocks plus spacers under the four frame contact hoist locations.
The jack stands take the load, the other four are my back up.
Thanks for all the replies. The diagram above with the listed contact points is a good reference...wasn't quite sure where to jack the car up with the jack. Regarding Harbor Freight, I remember there was a recall on their jack stands years ago....but figured they resolved that issue so was going to buy everything there. Now I'm having second thoughts about that too!
I use 4 6 ton ones also, for the height.
be aware that if you need to go pretty high you need to do it in two to three stages, the frame on these is really stiff, so jacking one corner will lift it off the other stands, then it starts rocking around.
I have quick jacks and they are quite good for some general maintenance but not for doing some things like lowering the engine and some other stuff, they get in the way.
I have the esco 10499 low profile jack stands.. really like them, especially when I jack the entire side up(from the rear side jack point) I can easily slide both jacks under
No rocking if you jack on centerline front and rear, but still jack in steps.
Hello, before my lift I used either 6x6 or 4x4 blocking cut at 10"long just turn the blocks like the game Jingo. Much more stable than jack stands.
home depot will cut to size free just takes a little figuring as to the height needed.
old school but safe
