2008 z51 engine & computer electrical diagrams
The engine will never shut down if the Shift Lever is anywhere except PARK. Put it in PARK and it will die in about 15 seconds.
I can't tell you how many electrical problems I have fixed on this car. It doesn't let you take the shifter out of PARK occasionally. Putting it in ACCESSORY MODE doesn't automatically release the shifter from PARK. It does if I step on the brake pedal.
I only have 21,000 miles on this car and I bought it brand new in 2008. It spent most of it's life parked in my hangar at Lantana Airport until 2015. I also own a 2005 C6 Coupe, 1997 Supercharged (Procharger) C5 Coupe, and a 2000 C5 Coupe 6 Speed Trans.
I had a catastrophic ABS EBCM in January 2015. There was a hole burned through the Plug, Receptacle, and circuit board inside the BCM. I had to splice a new pigtail into the harness and get a complete ABS/EBCM from a salvage company. Everything works fine with the ABS.
I also noticed that in SPORT mode, when you are using the paddle shifters, the DIC is not displaying the gear you're in. It is displayed in the HEADS UP display.
Occaionally the screen of the CD/DVD/Radio doesn't light up even though the sound system is working. Can't play CDs any more. Only the DVD for the Navigation display works.
I was an Avionics Technician at EASTERN AIRLINES until it closed down in 1991. I have tested every fuse inside and out, and have checked each relay, even the two under the toe board on the passenger side (RUN/STOP and I don't remember the other one).
I am still searching for the problem and I'm even thinking it might be a problem with the BODY CONTROL MODULE. I show no OBDII trouble codes except P1682, and that only comes on if I let it set for a while without disconnecting the battery.
I am driving the car almost every day and I love it but I have to disconnect the battery when I go home and park it.
I really appreciate your help with this issue. I've been tryig to figure it out for several years. Last time I submitted this problem on the forum I got a bunch of really smart-*** replies and I was disappointed nobody took this igtnition problem seriously.
I seem to be the only person whose car engine keeps running when I try to shut it off. Tell me what your address is and I might take a drive over there.
The P1682 concerns the Powertrain Relay which I wanted you to check…PM sent.
Removing fuse 1did not change anything. It still continues to run in reverse, neutral, or drive. It still only shuts down in PARK after about 15 seconds. In my 2005 C6 you can shut the engine down with the gear selector in any position.
Is there a vendor you would recommend that I could send my ECM to for repair, or should I just buy one from a salvaged vehicle? I just checked with car-part.com and there is no shortage of ECMs from other GM vehicles for around $200. If I bought one from another GM vehicle would I need to get it reprogrammed for my car specifically?
You mentioned pulling fuse 1 (TCM/TRANS) to see if the engine would shut down with the shift lever out of PARK. It still doesn't shut down unless it is in PARK. NO CHANGE.
I watched the video with the guy repairing the ECM circuit board. I did the same type of work for 6 years in the ELECTRONIC CONTROLS SHOP. at EASTERN AIRLINES.
We repaired nearly all the 385 black boxes that control the aircraft in house and recertified them to go back in service. I was the manager of that shop for the last two years we were operating. I trained all the new hires to do that kind of bench electronics repair work.
I made a typo when I was describing the ABS meltdown I had in 2015. I meant to say the Electronic Brake Control Module (EBCM) not the Body Control Module (BCM). I have never done anything with the BCM. I worried about melted insulation after seeing the damage done when the ABS system failed and melted the harness Plug, Receptacle on the EBCM, and the circuit board inside the EBCM. The largest pins in the EBCM plug which supplied current to the ABS Motor were VAPORIZED. I think there had to be a short circuit in the motor to cause that. I'll send you some pictures I took of the EBCM harness plug that I replaced when I figure out how to do that on this platform.
I only have a FOXWELL NT301 OBDII SCANNER. I don't have a sophisticated bidirectional tool to access the BCM.
I really wish I had access to those electrical diagrams you sent me. I could have fixed this car 3 years ago.I
I will order a new ECM from Flagship. I see that they don't want the old core from their ad. I'd like to get mine repaired. I could sell it on EBAY.
Do I need to get any numbers off my ECM to order the correct part from Flagship?
I can't thank you enough for sending me those diagrams.
It is looking like the RUN/CRANK RELAY might be staying closed by the BCM. I had the RUN/CRANK RELAY out and tested it manually many months ago. I didn't check to see if it was being driven closed all the time by the BCM though. It is looking more and more like the problem might be the BCM. What do you think?
I had to take a few days off from this car to clear my head. I got the new ECM from Flagship One over the weekend. They sent me the wrong RELEARN PROCEDURE, for cars with regular chipped keys. I got the correct ones today but I'm not sure about trying this on my own. I don't have the scanner equipment for the 10 Minute RELEARN. I might need to come and see you.
