Whining electric noise inside
Old Aug 10, 2023 | 08:19 PM
Gray Goat's Avatar
Gray Goat
Default Whining electric noise inside
Just happened on the way home today. It’s making a noise similar to a dentist drill. The noise goes up and down with the rpms. I shut it off and the noise was still there, just not as high pitched.
As soon as I opened the door it quit. I started it back up and it was still making noise.
Recently I started getting a “Service Electrical System “ message on the dash. The manual says to have a dealer check the ECU.
The ECU was programmed at East Coast Supercharger last year to get rid of codes from the CAI and O2 sensor. Also, the battery died over the winter and it’s brand new. Says over 14 volts.
I’ll be calling ECS tomorrow. Any thoughts?
Old Aug 10, 2023 | 08:36 PM
VetteVinnie's Avatar
VetteVinnie
Is it coming through the speakers? Aftermarket stereo or factory? Aftermarket amplifier? I've heard this happen when there's poor ground loop isolation.
Could also be the rear end.
Old Aug 11, 2023 | 05:48 PM
Gray Goat's Avatar
Gray Goat
Went to have codes read today. No error codes at all. I forgot to say it’s an ‘06.
The noise seems to be coming from the driver door speaker. All stock radio etc. He also checked the alternator and it’s good.
What stumps me is the noise continues when the engine is off. It doesn’t stop until you open the door.
Any ideas are appreciated.
Oh yeah, the service manager backed it into a guard rail. Almost knocked me over. Needs new Corsa exhaust and the back painted. Told me they would take care of it.
Old Aug 11, 2023 | 06:12 PM
torquetube's Avatar
torquetube
Pull the amplifier fuse (no. 31) and check if the noise goes away.
Old Aug 11, 2023 | 09:18 PM
Dano523's Avatar
Dano523
Yep, pushing the starter button to shut the motor off, just does that, while the rest of the modules are alive still waiting for the door open command before they start to shut down itself.
Hence should have noticed this, since radio will not stop playing until you do go to open the door, well after the you have shut the motor off via the starter button.
Old Aug 22, 2023 | 06:33 PM
Gray Goat's Avatar
Gray Goat
Okay, pulled fuse 31 for the Bose amplifier. Of course the radio is dead, but at least the noise is stopped. You wouldn’t want to drive with the noise. It would make you crazy.
There are no error codes and the alternator checked okay.
Still get “Service Electrical System” on dash. It definitely comes on if you step on it. But, also sometimes if just idling.
Please give me some ideas on what to check.
I’m surprised nobody commented on the repair shop backing it into the guard rail. Got an estimate of $900 to paint the back. Plus a new Corsa Sport exhaust.
Old Aug 22, 2023 | 06:47 PM
Dano523's Avatar
Dano523
Sounds like after market radio, and after market radio adapter was not wired/set up correctly, and have ground loop noise.
Old Jan 24, 2026 | 10:04 AM
DRiedel's Avatar
DRiedel
7th Gear
I had the same issue with my 08Z....factory navigation head unit and Bose.
Pulled fuse 31 and whine is gone. I'm guessing it's got a bad head unit/amp.
Old Jan 25, 2026 | 09:35 AM
1Hotrodz's Avatar
1Hotrodz
Somewhere a capacitor is not suppressing RFI. Could also be a bad ground. And your service manager is a TOOL!!
To Whining electric noise inside
