Johnson 2110R preload - pushrod length
Old Aug 22, 2023 | 08:44 AM
bwill03z's Avatar
bwill03z
Default Johnson 2110R preload - pushrod length
What preload are you guys running on Johnson 2110R lifters? I know what Johnson recommends but wanted some real world feedback. Do they seem to like the high side or low side of what Johnson recommends?
Also for anyone using these lifters and stock LS3 heads, what pushrod length did you end up with? I know you have to measure and length will vary with different cams… I have a BTR stage 2 cam and stock heads. I’m currently on a 7.425 pushrod but imagine I will end up with something like 7.350 or 7.375. Thanks
Old Aug 22, 2023 | 09:30 AM
Spaceme1117's Avatar
Spaceme1117
I am running stock LS3 heads with the LS9 cam but also using the thicker LS9 head gasket. I measured the preload on both banks of the engine the front cylinder (intake and exhaust) and went with a 7.375 length push rod. This put me right at 0.050 preload. Johnson spec is 0.035 +/- 0.010 but an extra 0.005 is fine. There is plenty more travel of the plunger.
I think you were running Morel lifter previously? They call for a 0.060 preload so going to the Johnsons, you would need a 0.025 shorter rod (assuming everything else is the same and you were running that preload). So maybe a 7.400 is what you need.
But of course, need to measure.
Old Aug 22, 2023 | 10:21 AM
double06's Avatar
double06
Another point is you need to compare lifter heights from pushrod cup to lifter wheel. This is if you had an oem lifter to start and are changing over. Not all lifters are 2.45 or whatever it is inches. Thae oem lifter take more preload so you may have a double adjustment for lifter height and preload delta
Old Aug 22, 2023 | 11:14 AM
Spaceme1117
100% true.
I think the OP is going from Morel's to the Johnsons. I did the same in my car (Morel's to Johnsons) and I measured the cup to bottom of roller wheel distance. I used a ball bearing about the size of the end of a push rod to try to match the fit of the pushrod in the cup. I found the wheel to cup distance was the same. Not sure if this is true going from stock LS7 lifters to Johnson's however.
But again, need to always measure.
In my case, I used the Comp Cams pushrod length checker and also verified the preload counting turns of the rocker arm from zero lash to proper torque and they both were where they were supposed to be.
Old Aug 22, 2023 | 11:29 AM
bwill03z's Avatar
bwill03z
Originally Posted by Spaceme1117
100% true.
Yep, going from the Morels to the Johnsons. I was using a 7.425 with the Morels and with that I was around .060 preload on most of the intake lifters but a little more on the exhaust side.
And I cannot confirm but I’ve heard the Johnsons are the same as LS7 lifters on cup to wheel length.
Old Aug 22, 2023 | 12:41 PM
Spaceme1117
That being the case, a 7.400 push rod should put you at the perfect preload for the Johnson's then.
Old Dec 18, 2023 | 10:29 PM
Jimmywebb56's Avatar
Jimmywebb56
1st Gear
I know everyone hates reopening a discussion but I am curious if your original push rods fit? I too am weary of installing junk lifters. I’m doing a l83 engine with 7.84 rods. The man at Texas speed is telling me they have been not had any issues from customers using their same rods.
I WILL of course measure and am capable of doing so but I need my daily back on the road. I went through a fiasco after receiving poor quality gm ls7 lifters but have returned in exchange for credit towards Johnson 2110r’s.
Old Dec 19, 2023 | 10:54 AM
Spaceme1117
If you are only changing the lifters from the stock LS7 to the Johnson's, you will need a shorter push rod. The Johnson 2110R preload is 0.035 +/- 0.010 whereas the stock LS7 preload is about 0.080. Stock pushrods are 7.400 so you should need a 7.350 length rod. (But you still should measure and verify).
Now, if there are other changes such as different cam, rocker arms, milling the heads, or the block deck, all bets are off and you absolutely need to measure for correct pushrod length.
The guy as Texas Speed should be punched in the face. You need to get the correct pushrod length for your setup. Just throwing a 7.4 rod in and hoping it will work is just plain stupid. There is a reason there are specifications for the parts in an engine.
The Johnson 2110R's only have about half the plunger travel of the stock lifter. If you have too much pushrod length (and with a 7.4, you likely would), it is possible that the plunger bottoms out and that would be very bad.
Old Sep 2, 2024 | 05:21 PM
grinder11's Avatar
grinder11
Bringing this back from awhile ago. I'm currently installing 2110Rs I bought from Tony Mamo. They're going in an LS7. However, you've got to measure! Can't just go by different preload specs. Why? Because that's assuming the pushrod cup on each lifter is the same height above the lifter wheel as the LS7. They are NOT!! I recently measured both the LS7 and Johnson lifter height with a 5/16 ball in the pushrod cup. Distance from the wheel to the top of the 5/16 ball is approximately .040" shorter on the Johnson lifter, give or take .001". So if the preload specs were the same, which they're not, you would actually need a LONGER PR for the Johnson. Keep this in mind before changing and ordering new PRs. Best way is to use a PR length checker, which I also bought from Tony. Hope this helps......
Old Sep 2, 2024 | 06:45 PM
bwill03z's Avatar
bwill03z
Yeah the Johnsons are a different height than the LS7 lifters but they also require less preload. I was using 7.400’s with my LS7 lifters and oddly enough needed a 7.400 with the Johnson’s to get me where I wanted to be on preload, which I believe was like .045
Old Sep 2, 2024 | 07:19 PM
Spaceme1117
ALWAYS have to measure.
Old Sep 3, 2024 | 07:58 AM
Spaceme1117
You are correct. When I switched from a standard LS7 lifter to the Johnsons, the pushrod length I needed did not change. Preload is less for the 2110R's (0.035 +/- 0.005 if I remember correctly) but the cup depth is is indeed shorter.
Likely Johnson did this on purpose to simplify for people so they don't need to change their pushrods if it is only a lifter replacement. LS7 preload is about 0.080 with a 7.4" pushrod on your typical LS engine (except the LS7). If you only change the lifters from stock LS1 or LS3 to Johnson 2110R's, it would still need a 7.4 pushrod (or 7.8 for an LS7). Well thought out and good engineering on Johnson's part.
Old Sep 5, 2024 | 06:08 PM
grinder11's Avatar
grinder11
I agree, especially when retaining stock rockers. But I also changed rockers, going with YT #6670s. LS7 has 7.800" long stock PRs. But the YTs changed everything, and I'm now looking at 7.750" lg PRs.
Old Jan 25, 2025 | 10:04 AM
c6j0hn's Avatar
c6j0hn
2nd Gear
You are correct. When I switched from a standard LS7 lifter to the Johnsons, the pushrod length I needed did not change. Preload is less for the 2110R's (0.035 +/- 0.005 if I remember correctly) but the cup depth is is indeed shorter.Likely Johnson did this on purpose to simplify for people so they don't need to change their pushrods if it is only a lifter replacement. LS7 preload is about 0.080 with a 7.4" pushrod on your typical LS engine (except the LS7). If you only change the lifters from stock LS1 or LS3 to Johnson 2110R's, it would still need a 7.4 pushrod (or 7.8 for an LS7). Well thought out and good engineering on Johnson's part.
im looking to these get these same lifters for my ls3 and I thought they needed a shorter pushrod? Not a 7.4
Old Jan 25, 2025 | 11:55 AM
DSOMC6's Avatar
DSOMC6
I have a brand new set of Manley 7 375" PR's if anyone needs them. $75 shipped ($150 new). Still in the box.
To Johnson 2110R preload - pushrod length
