Bad Ignition Switch or Button?
Old Sep 11, 2023 | 06:38 PM
Tim81's Avatar
Tim81
Default Bad Ignition Switch or Button?
Ok if you want to flame me for asking this question then go ahead. I’ve been chasing a EBCM problem for awhile now. I’ve cleaned every connection and ground in this car. Also have checked the voltages and replaced the battery. I’ve sent the module in for repair twice, the second time was my fault. I noticed today that first start up in the morning everything is fine but if I shut it off and restart it again it gives me U121 and U2108. Let it sit for a couple of hours and it’s fine again. My question is could it be the ignition switch causing this? Also is the switch difficult to replace? Going to check the wiring diagram tonight. Thanks for any thoughts at all.
Old Sep 11, 2023 | 07:15 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
These are “loss of communication with EBCM”…what voltages and ground were checked ???…for any module “no comm” you want to check that modules POWERS and GROUNDS…there are 2 battery and one ignition feed and a ground…check them first before condemning the module.
Old Sep 11, 2023 | 08:33 PM
Tim81's Avatar
Tim81
[QUOTE=C5 Diag;1607035028]These are “loss of communication with EBCM”…what voltages and ground were checked ???…for any module “no comm” you want to check that modules POWERS and GROUNDS…there are 2 battery and one ignition feed and a ground…check them first before condemning the module.
[/QUOTE
Hi C5Diag, I have both constant 12v and the IGN 1 12v at the EBCM connector. I also have both Gnds . I checked them by back probing the connector like you have suggested before. The connector was checked with the ignition on and Abs light lit. With the battery disconnected the Can Bus measure 61.2 ohms.
To Bad Ignition Switch or Button?
