Rotating Assembly- Made in USA
Old Sep 27, 2023 | 07:09 PM
JSA310's Avatar
JSA310
Default Rotating Assembly- Made in USA
I’m sure this has been discussed a million times, but times change, and I am investing tens of thousands in a new LS7 to include a Dart aluminum block, TFS 6 bolt heads, BTR cam to name a few parts.
I would like a top of the line rotating assembly for the best N/A performance. The motor will see high reving street and road coarse driving. Around 7,500 rpm redline. And, I want something quick reving, light, strong, durable and Made in the USA is a must. No Chinese crap in this +$25k motor!
I have been looking into Oliver rods, Carillo rods, Lunati X beam rods. And I’m confused on which crank options there are. Again, I want the best parts available - no expense spared. And they must be 100% made in the USA.
Thanks in advance for your help.
Old Sep 27, 2023 | 07:22 PM
ClothSeats's Avatar
ClothSeats
You might try joining the Facebook group "LS7 Engine Tech" and ask your question there. The administrator there (Semir Metovic) is a professional builder of high end LS7 engines. He will offer some good advice.
Old Sep 27, 2023 | 07:28 PM
JSA310's Avatar
JSA310
Thanks, but I don’t do FB.
Old Sep 27, 2023 | 09:33 PM
Dano523's Avatar
Dano523
Lost here, since the block in play, as well as the heads, are designed for high levels of boost, and your talking a N/A application were a stock block and standard bolt heads are more then enough for the task as hand.
As for higher reving motor, then need to move towards over square set up . But even with this, still at the limitation of what the heads and intake can flow, as well as what you are limited on a push rod motor to as well.
Bluntly, for the money is sounds like your talking for a N/A set up for the street, should have just picked up a SB4 motor isntead.
Old Sep 27, 2023 | 09:59 PM
old motorhead's Avatar
old motorhead
Generation IV Internal Engine - LS1TECH - Camaro and Firebird Forum Discussion
Old Sep 27, 2023 | 10:16 PM
JSA310's Avatar
JSA310
Fair statement.
I like the idea of the 427 ci displacement, but I have considered a 388 ci. Not too late to do that.
The block is a “bulletproof” option. And it also allows me to pull the stock LS7 out and keep it completely in tact.
My idea is to build a LS7 that will last, rev high, make great reliable power, and I have the option to MAYBE add a supercharger. And that’s a big maybe as I am a track guy with over 10 years experience at tracks like Road Atlanta.
Old Sep 27, 2023 | 10:48 PM
Last 1's Avatar
Last 1
I would just call CNC Motorsport have them build me a short block
they build them with Callie Magnum Crankshaft with a center counter weight ,Lunati pro I beam rods or Dyers H beams 300m rods
je pistons (light weight)for NA and Dart blocks
and just buy your TFS 260x heads from Tony Mamo
To Rotating Assembly- Made in USA
