Spark plugs - keep these or swap?
Old Dec 3, 2023 | 10:15 AM
grinder11's Avatar
grinder11
Originally Posted by old motorhead
The ground electrode on that plug is pretty damn tough. It would take a fairly substantial blow to change the gap. If the box they came in is pristine, the chances that one or more of the gaps has changed are slim and none. I've never measured one. I take them out of the package, lay them on the work bench, and make sure they look the same. Add a little dab of never seize and in they go. I know adding never seize is blasphemous. Just shoot me
I changed my gaps by just holding the plugs with my thumb and forefinger and then tapped it gently against the wooden bench top..
Old Dec 3, 2023 | 11:21 AM
old motorhead's Avatar
old motorhead
Originally Posted by jonjoy
THE SPARK PLUG MANUFACTURERS TELL YOU NOT TO USE NEVER SIEZE, The base of the plug is it's ground, the never seize can inhibit that!
Just shoot me...
And If I see a new plug that obviously bad, I won't change the gap and I won't measure it. It's going back from whence it came.
