2013 427 collector edition
Old Nov 29, 2023 | 09:56 AM
sidebycycle's Avatar
sidebycycle
Default 2013 427 collector edition
When accelerating I get a noise (that I can only describe as sounding like shaking rocks in a can) in the RPM range of approximately 800-1500. I believe it happens in both 1st and 2nd gears but I so seldom have the car in this range in second gear, that I may be mistaken. I otherwise don't hear it or, what I would consider, any other unusual noises. My car has approximately 29,000 miles on it. There are also times when shifting from 1st to 2nd gear I can't get it into 2nd unless I double clutch. Are these things related? Any ideas on how to rectify these issues? Thanks in advance for any help.
Old Nov 29, 2023 | 10:11 AM
ClothSeats's Avatar
ClothSeats
Does it sound like engine pre-ignition? Do you have any trouble codes?
Old Nov 29, 2023 | 10:35 AM
sidebycycle
Definitely not pre-ignition and no trouble codes.
Old Nov 30, 2023 | 12:43 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
try this:
https://www.corvetteforum.com/forums...fixed-pic.html
Old Nov 30, 2023 | 03:00 PM
sidebycycle
Thanks to both you and "ClothSeats" for answering me. I have always found this forum to be helpful. Any other thoughts from anyone about either of my two issues mentioned are very welcome. I currently don't have a jack or ramps to raise my car but will look at the springs when I next take it for oil change.
Old Dec 5, 2023 | 10:11 AM
BLUEMEANIE's Avatar
BLUEMEANIE
Is it a heat shield that rusted part way off?
Old Dec 6, 2023 | 10:21 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
shifter rattle?
Old Dec 7, 2023 | 09:46 AM
sidebycycle
Thanks. I can't get under the car but when I do oil change will look then. That said, this car is relatively spotless underneath, I don't think this is the problem. Thanks again for the help.
Old Dec 8, 2023 | 11:42 AM
tektrans's Avatar
tektrans
I had something similar when I reinstalled my exhaust after header install. Had small header leak and the 2 mid pipe flanges were hitting each other a bit at low rpm.
Old Dec 9, 2023 | 12:05 PM
sidebycycle
Thank you Tommyc6z06. I will check this out.
Old Dec 11, 2023 | 02:15 PM
sidebycycle
After driving my car holding the shifter it seems to have reduced the noise. I'm not yet ready to say this is definitely the problem. Is there any way to adjust the shifter so it doesn't rattle? Thanks for the help.
Old Dec 11, 2023 | 02:22 PM
tommyc6z06's Avatar
tommyc6z06
i had mentioned that (above) because mine was doing that at about 19k very gentle miles.
i bought an MGW shifter. Problem solved and eliminated all the vagueness too
To 2013 427 collector edition
