LS2 Throttle bodies.
Old Nov 29, 2023 | 05:02 PM
lght spd's Avatar
lght spd
Default LS2 Throttle bodies.
I'm in need of a larger bore throttle body. 2005 C6 with LS2.
I know nick williams is the gold standard with the drive by wire throttle bodies. But damn they are spendy. I also know you get what you pay for.
I see that a few other companies have stepped into the ring sort of speak for throttle body supply.
Summit Racing has a private label version, Granatelli, and new to the game Speedmaster from Australia has joined with an offering.
In past years Ive seen horror stories of the throttle blade motors being the issues on alot of the non-nick williams throttle bodies.
Does anyone have any feedback on any of the 3 options I mentioned above.
Old Nov 29, 2023 | 06:55 PM
Dano523's Avatar
Dano523
Lets back this up, and is it that you need to replace or rebuild a faulty TB, or think that a larger/ported TB is going to gain you power itself isntead?
Old Nov 29, 2023 | 07:12 PM
lght spd's Avatar
lght spd
None of the above. Bigger Motor, Bigger Blower.
Old Dec 1, 2023 | 11:04 AM
lght spd's Avatar
lght spd
Bump...
Old Dec 1, 2023 | 11:17 AM
old motorhead's Avatar
old motorhead
Suck through or blow through?
Old Dec 1, 2023 | 02:52 PM
lght spd's Avatar
lght spd
A&A Kit with Vortech Head Unit.
Old Dec 2, 2023 | 05:23 PM
jonjoy's Avatar
jonjoy
90MM will support 1200 HP, you don't need a bigger TB, you might want to go to the LS3 card style MAF and the after market tube it fits in.
Old Dec 9, 2023 | 08:21 PM
lght spd's Avatar
lght spd
is there any advantage to porting the factory throttle body? I’m on the west coast, what companies that are reputable do this service?
Old Dec 9, 2023 | 08:26 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I am running a 95mm LS2 Silverblade from Solar Performance on an LSA blower. It runs perfectly. They are around 600 bucks and use factory GM housings and electronics.
Old Dec 11, 2023 | 09:58 AM
jonjoy's Avatar
jonjoy
No porting does little or nothing and it makes tuning harder
Old Dec 12, 2023 | 08:10 AM
grinder11's Avatar
grinder11
I disagree. On a stock setup, you are probably correct. On a modded, larger displacement, N/A engine, it can make a measurable difference. Tuning an engine with one, according to my tuner, makes little difference in the difficulty factor, and is much easier to tune than a larger TB. Turning this over to @Tony @ Mamo Motorsports
Old Dec 12, 2023 | 08:53 AM
Tony @ Mamo Motorsports's Avatar
Supporting Vendor
Porting the OEM TB is a no brainer if you don't want to spend the extra money for a larger 103
Difficulty in tuning is not an issue (more challenging moving up to the 103 in that department) and its adds measurable throttle response and some peak torque and peak power also
In boosted combo's you pick up even more gains across the board.
Its a fantastic upgrade for the cost....honestly its one of the first mods everyone should make regardless of how mild or wild the combo (big bang for the buck)
Feel free to reach out to me via phone or email if you would like to discuss in more detail
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Old Sep 30, 2024 | 03:18 PM
BoostedLS99's Avatar
BoostedLS99
Hey Mr. Black, I also have a 92mm LS2 Silverblade from Solar Performance that I plan to put on my LSA Blower. Did you have to use an adapter to physically get the TB to fit onto the Blower opening? Or does it line up and bolt up perfectly fine?
Thanks for the help!
Old Sep 30, 2024 | 07:49 PM
Mr. Black's Avatar
Mr. Black
Straight bolt on with smooth transition.
You will love it!
Old Sep 30, 2024 | 08:41 PM
old motorhead
If you're wondering whether a bigger throttle body will help, measure intake manifold vacuum at full throttle. If there's vacuum there, there's a bottle neck/restriction ahead of the intake manifold. Could be throttle body or it could be air filter/CAI. Check that and isolate the source of the vacuum before spending money. If you have no vacuum there, you can't do much better than that...no matter how much money you spend.
Old Oct 1, 2024 | 12:11 PM
jonjoy's Avatar
jonjoy
90 mm will support 1200 HP, the LS2 MAF is only 82mm? get the billet MAF body that uses an LS3 card style MAF. That opens up any restriction.
Old Oct 1, 2024 | 07:02 PM
Mr. Black's Avatar
Mr. Black
I couldn't imagine NOT running an LS3 MAF in any modified car even in a C5.
Running a tiny MAF is counterproductive.
To LS2 Throttle bodies.
Old Oct 2, 2024 | 04:07 PM
BoostedLS99
You will love it!
Thanks Mr. Black and everyone else for replying.
I have been following the C5 LSA Build on your YouTube channel for a while and it's awesome. I had some questions that maybe you would have insight on?
1) Anyway to get the LSA on the car without having to cut the Wiper Cowl? (I don't care about the plastic trim piece so much, but more about the metal part itself). Any "low-key" low profile LSA Blower Lids out there? Will an LS9 Style LID Help? Can it bolt straight to the LSA Case?
2) Is there any downside to having to run the Cathedral to Square adapter plates? This is one of the things making me thing twice or three times about going with an LSA, vs. a Harrop 2300 or Whipple 2.9 (which can come directly with Cathedral Port runners)
Old Oct 2, 2024 | 05:39 PM
old motorhead
A Magnuson Heartbeat will bolt up to square port heads and fit under the stock hood (C6 anyway). Eforce is available for catty port or square port heads and also fits under the stock hood. Both are TVS2300's.
Old Oct 4, 2024 | 11:42 AM
Mr. Black's Avatar
Mr. Black
Are you working on a C5 or C6? On a C5 you have to cut a 1 x 10 inch piece of the firewall/cowl off. It is NOT metal. It is just composite. It is because of the adapter plates and blower case. There is no lid that will change this. Lids will only affect hood choice.
Hindsight being what it is, I will never run a square to cathedral adapter plate ever again. They work fine in a WOT environment like racing/drifting but are less than to be desired for daily driver street manners in the tune department. There is just too much fuel puddling in the adapter plate from the way the LSA injector port fires the fuel in to the adapter.
I am actually thinking about making the switch to a C6 based square port Whipple 2.9 liter blower this winter just for the fun of it.
