P0641
Old Jan 11, 2024 | 07:11 PM
sicvett2011's Avatar
sicvett2011
7th Gear
Default P0641
Getting reduce engine power and service traction control I have replaced throttle body , accelerator pedal and 4 sensor in circut A code still came back help please.
Old Jan 12, 2024 | 07:06 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What year is the car ??…there is no info in your profile…there are 2 each 5 volt reference circuits that come from the ECM and P0641 is circuit #1…there are 6 sensors involved in that circuit…with a scan tool and looking at that 5 volt reference circuit start disconnecting each sensor…when scan tool goes from “fault” to “OK” you’ve found the bad sensor…if disconnecting each sensor does not resolve your issue you have a wiring sensor…possible short to ground !!
Old Jan 12, 2024 | 08:08 AM
sicvett2011
7th Gear
I have a 2011 Grand Sport circuitA reference #1 replaced Map, Oil,A/C,Fuel I'll get the other 2 listed checked out thanks
Old Jan 12, 2024 | 09:27 AM
Jfryjfry's Avatar
Jfryjfry
While unlikely, check even the ones you replaced to rule out a bad sensor out of the box.
Old Jan 14, 2024 | 01:14 PM
Sayfoo's Avatar
Sayfoo
https://www.corvetteforum.com/forums...ng-lights.html
Clean/replace maf sensor???
Old Mar 3, 2024 | 05:29 PM
sicvett2011
7th Gear
Default Still getting P0641
Still getting code P0641 after having it checked out, the strange thing it will set off code and the next morning when I go to take it back to shop the check engine light and service traction control lights are out and car performance is normal.
Old Mar 3, 2024 | 06:11 PM
grinder11's Avatar
grinder11
Are you saying that when the engine cools completely after sitting all night, all is good? If so, when does the code return? After the engine is completely warmed up again? Or does it behave randomly, and all is well for 2 or 3 days, or? The more complete info you can provide will help people zero in on the issue......
Old Mar 3, 2024 | 08:42 PM
sicvett2011
7th Gear
Yes, Grinder exactly how you explained it is what is going on.
Old Mar 4, 2024 | 09:35 AM
grinder11's Avatar
grinder11
Originally Posted by sicvett2011
Yes, Grindertittt exactly how you explained it is what is going on.
Which EXACTLY?? Random, or the next time it warms up completely?? Every time it is driven to normal operating temps???
Old Mar 4, 2024 | 09:39 AM
C5 Diag's Avatar
C5 Diag
Other than the P0641 what other DTC’s were set ??…don’t know what type of shop you took your car to but find yourself an auto-electric shop to diagnose this…intermittent issues take a little time to diagnose!!
Old Mar 4, 2024 | 05:21 PM
sicvett2011
7th Gear
I can drive the car for 2 or 3 days. It gets to normal operation temperature. And then when I start to accelerate it goes into the reduce engine mode /service traction control. Then if I dont drive the car for a day or so the codes go away.
Old Mar 5, 2024 | 03:22 AM
Psychokiller Z06's Avatar
Psychokiller Z06
I've delt with this and car has been down a few months. Chasing electrical gremlins is a pain. I honestly just started rewiring everything around the headers and starter. Mine is a bit different as it is constant now.
Old Apr 8, 2024 | 12:19 PM
sicvett2011
7th Gear
Default P0641
Still no luck fixing p0641 issue, took it to dealership they said fuel relay then App sensor still not fixed. I've tried some of the suggestions still no luck.
Old Apr 8, 2024 | 12:31 PM
C5 Diag's Avatar
C5 Diag
First mistake was taking the car to a dealership for a diagnosis...they're clueless !!...if this 0641 keeps popping up take the car to an auto electric shop...unless you understand how the 5 volt reference circuit operates you are just wasting your time !!
Old Apr 11, 2024 | 03:36 PM
MikeFloyd's Avatar
MikeFloyd
100% you should diagnose the problem with the right scanner and only change out a bad part. Then verify that the new part is good. Throwing parts at a problem can create more problems.
To P0641
