ECM service numbers
Old Jan 21, 2024 | 04:29 PM
Zo6_shawn's Avatar
Zo6_shawn
Default ECM service numbers
So my ECM is having communication issues . It won’t even let my tuner get in with his HP tuners. We are thinking it’s corrupt so I’m just going to get another one.. however I don’t want to pull the fender off myself so I’m going to have a shop swap it out. But they want me to get the ecm first. So I can’t just look at mine to determine what to get. Does anyone know which ECM service number I need? It’s for a 2008 Z06. I’ve tried contacting the dealer but they were no help .. thanks in advance
Old Jan 22, 2024 | 05:27 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Before replacing an ECM for communication issues I’d check the ECM powers and grounds first.
Old Jan 22, 2024 | 07:48 AM
Zo6_shawn's Avatar
Zo6_shawn
the powers and grounds are fine . It has power and let’s OBD scanners work fine.. it’s only when the HP tuners tried to communicate, will it say it doesn’t recognize the port.. it’s been glitchy for a while , we had an issue when we tuned it the first time and since then the ecm has been corrupt .. it even changed some of the fuel trims after the tune .. it’s just very odd
Old Jan 25, 2024 | 12:16 PM
SpeedyWs6's Avatar
SpeedyWs6
Just buy this.... https://dsxtuning.com/collections/tu...21286585401424
or
The ECM E38 was used in so many vehicles that GM made in 08. If the shop has GM SPS2 capabilities then you simply install an ECM from a truck and flash it to your car.
Old Feb 4, 2024 | 11:28 AM
KENS80V's Avatar
KENS80V
The correct E38 ECM for your 08 Z06 car is #12612384. It was used across many 08-09 GM models and can be found rather cheaply at your local wrecking yard. You could then find someone local to reprogram it. It needs to be programmed with a 08 Corvette OS. Give the tuner/programmer your VIN and the exact updated software will be loaded. Do not program it with HP Tuners or EFILIVE software as it will not include all the segments. It must be programmed thru GM database.
Even if the issue you are having is not with the current ECM it's still a great idea to have a spare E38 ECM handy. As time goes by they will eventually become harder to find.
Old Feb 5, 2024 | 09:27 AM
Zo6_shawn's Avatar
Zo6_shawn
Default Fixed !!
Definitely was a corrupt ECM.. swapped it out and the tuner reprogrammed it and uploaded my Tune.. all worked well .. thanks for the help
To ECM service numbers
