throw out bearing
Old Jan 28, 2024 | 05:16 PM
russ472's Avatar
russ472
Default throw out bearing
doing some maintenance and found my throw out bearing has some wobble from the inner race to the outer bearing. have some play in my torque tube shaft as well. going to rebuild. does anyone know if I can get the throw out bearing separately from the slave cylinder? mantic twin clutch and oem slave only has around 10k miles on them.
Old Jan 29, 2024 | 06:17 AM
Spaceme1117's Avatar
Spaceme1117
Just change the whole thing. If the throw out bearing has some slop, the slave likely has wear as well. But you should upgrade to an aluminum bearing supports as the stock one is plastic. Monster sells an alumninum one and a few other vendors.
Old Jan 30, 2024 | 01:34 AM
trapvette's Avatar
trapvette
+1 for the billet sleeve. I ignored it when i did my clutch. This is my plastic one after 30k. Suprised it lasted that long since I did 10 strip passes on slicks and 3 autocross events on it
Old Jan 30, 2024 | 08:18 PM
Jfryjfry's Avatar
Jfryjfry
Quartermaster makes a great billet spacer that is the most affordable I found.
To throw out bearing
