Did you mean a damaged REAR end? I ask because a car thats been in a front end collision is less likely to have a good FRONT turn signal anything than one hit in the rear. Another place to try would be Vettenuts. I know they have C5 parts, not sure on any other series.....
either or.. the socket that he is looking for could survive a front end collision, could it not?
Okay, here is what I did. I took the socket out of the new housing and put it in the old housing. There are two tabs on the side of the socket you push in and the socket slides out of the housing. Once the socket is out of the housing the wires pull out. You don’t even need to cut any wires, just pull the old socket out and pop the new one in.
