Have a p1 procharger throwing the p102 code the maf sensor is relocated to the bottom of the intake any help on how to clear also where to buy new sensor
p0102 code means your MAF frequency is below a set limit (around 10 Hz) so the PCM is declaring your MAF non-functional.
Also, The maf really isn't the problem, its the hardcoded limit in the pcm, GM got wise & upped the limit for 08' LS3's.
Ls7 btw i was doing some test rolls and got the code when i got into it i reset the maf as it said online and it hasn't happened since was thinking that the maf wasnt used to the excess airflow
