cooling fan removal
Old Feb 16, 2024 | 03:23 PM
wood78221's Avatar
wood78221
Default cooling fan removal
What's the consensus here, remove this fan from the bottom or top?
Old Feb 16, 2024 | 06:01 PM
russ472's Avatar
russ472
bottom.. super easy
Old Feb 16, 2024 | 08:32 PM
baxsom's Avatar
baxsom
Bottom. Swing down the front sway bar
Old Feb 16, 2024 | 10:49 PM
Aardwolf's Avatar
Aardwolf
Last one I worked on an '05 it was easy from the top.
Old Feb 20, 2024 | 08:23 AM
double06's Avatar
double06
Bottom. I think also the first year 2005 it was a little more difficult and they changed the housing the next year to make it easier to get out. I think also if you can undo the upper radiator housing mounts and push the radiator toward front of car a little it helps clears the ABS stuff on drivers side.
Old Feb 21, 2024 | 01:36 PM
grpweld's Avatar
grpweld
Bottom
To cooling fan removal
