ls2 heads suggestions
Old Mar 1, 2024 | 07:10 PM
justaLS2's Avatar
justaLS2
7th Gear
Default ls2 heads suggestions
i have a stage 3 cam 1 7/8 long tubes and yank 3200 stall sitting in the garage but have no idea what i should look at for heads. anyone have any suggestions? it’s an ls2 and eventually want to get one of pro chargers kits.
Old Mar 2, 2024 | 09:56 AM
old motorhead's Avatar
old motorhead
If I knew a supercharger was in my future, I wouldn't spend a bunch of money on cylinder heads. Maybe send your stock heads off for a CNC port job, valve job, cleaning and assembly ($900 at Tx Speed). I wouldn't use any kind of stage 3 cam with a blower either. You don't need an ill mannered cam when you have positive manifold pressure.
Old Mar 5, 2024 | 12:35 AM
bignikmusic's Avatar
bignikmusic
I was going to send mine to TSP to get ported, because that is huge bang for the buck. but I didn't want the downtime. So I bought trick flow 225 full CNC heads from summit. They work great with my cam and I picked up like 45whp. I had to get roller rockers too tho, and tall valve covers, and correctly sized pushrods. So a lot of additional expense.
Old Mar 5, 2024 | 07:24 AM
old motorhead
I didn't want the downtime either. I found a low mile used set of heads online to send out for porting. I had every piece to complete the job before turning the first wrench. We did heads, cam, exhaust, suspension, etc. all in a long weekend. Sold the heads that came off of my LS3 after completing the work. Back then, you could find low mile take off LS3 cylinder heads for +/- $450. Not so easy to find good used heads for a reasonable price anymore.
Old Mar 5, 2024 | 07:49 AM
grinder11's Avatar
grinder11
^^^^^^^^^^This^^^^^^^^^ is having all your ducks in the right row. Another set of cathedral port heads I'd throw into the mix would be AFR 225s/230s. I had a set on my 427 Darton motor. They were great. But I do agree with old motorhead that spending $3,000+ on heads wont give you the bang for the buck a blower with ported OEM heads will. No blower, they're great. Not needed with the blower. FI will make up for a port job.......
Old Mar 5, 2024 | 08:00 AM
Burntoutaccountant's Avatar
Burntoutaccountant
If you’re going supercharger get ls3 or lsa heads.
Old Mar 5, 2024 | 10:12 AM
da6speed's Avatar
da6speed
What the above poster said.
IF you are going with a procharger later, I would HIGHLY recommend swapping to a ls3 head/intake. It will make more power with the ls3 heads over the ls2 heads with the same cam and blower pulley on both setups. Been there, done that. I went 5.90s years ago with 6.0, jam cam, ls3 heads/intake, 1-7/8 headers, procharger, yank pas3400 on 93 pump gas/meth.
Old Mar 5, 2024 | 06:19 PM
grinder11's Avatar
grinder11
da6speed, for clarity, did you run GM LS3 heads on the 6.0, or aftermarket LS3 heads?.....
Old Mar 5, 2024 | 06:43 PM
old motorhead
I know this is going to sound absolutely insane.....but, here goes... ").({better, more expensive heads make more power}).(". If there's no line in the sand that you have to stay behind cost wise, absolutely open the flood gates and let the $'s rain. Somehow, I though the OP wasn't looking for that kind of build. Maybe he needs to jump on here and explain his goals and budget.
Burntoutaccountant
I’d check ls1gto. It’s a very common swap on the ls2 gto. I personally did it. Very straight forward process. I bought the used factory castings, not gm cnc ported heads. Factory manifold as the ls3 manifold flows great and can make power.
Old Mar 6, 2024 | 10:19 AM
da6speed's Avatar
da6speed
They were actually stock lsa heads (same ports, etc as ls3, just stronger material). I now have a whole new setup and use some worked Brodix BR3 heads.
Old Mar 6, 2024 | 04:04 PM
30rpm's Avatar
30rpm
Rec ports have a larger chamber for lower compression and flow a lot better than cathedral ports. You'll make more power NA and not need as much boost to make the same power FI. Also might want to consider a LS9 gasket.
To ls2 heads suggestions
