Powerglide swap problem
Old Mar 5, 2024 | 11:49 PM
pbinutah's Avatar
pbinutah
Default Powerglide swap problem
2008 base c6. Installed power glide, car will not start due to needing to bypass ecu. Car was auto before, any ideas thank you so much! Also on stock ecu! Thank you in advance!
Old Mar 6, 2024 | 09:06 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I would assume you need to retune the car into thinking its a manual. I would check with your tuner.
