Need to back it up, hence more details, since higher pressure or volume pump that the motor does not needs, just means the blow by piston is being opened up more.
Also, if you need a high volume pump on a stock motor due to low oil pressure, may want to figure out where you losing oil pressure in the motor to begin with.
No no no oil pressure is good. I want to instal cam kit from BTR + hydraulic lifters ls7 style+ better oil pump
Question is - are ls3 really need hight pressure oil pump? 44k miles odometer
