Clutch position sensor Code PO0833
Old May 14, 2024 | 12:36 PM
Maymax12's Avatar
Maymax12
4th Gear
Default Clutch position sensor Code PO0833
Hi I need some help, recently when i push my clutch in the engine rpms go up 300 to 400 then come down. Check engine light comes on and my code reader is saying PO 0833. I've read there are 2 sensors, does anyone know which one might be the problem or is there something else that could cause this problem. thanks in advance
Old May 14, 2024 | 06:59 PM
Dano523's Avatar
Dano523
P0833 Clutch Pedal Switch 2 Circuit ECM
https://www.corvetteforum.com/forums...cs-please.html
