2005 Automatic Shifter Sticking (Not the usual Problem)
Old Jun 18, 2024 | 01:25 PM
waybadsrad's Avatar
waybadsrad
1st Gear
Default 2005 Automatic Shifter Sticking (Not the usual Problem)
Hey guys so I wanted to see if anyone has encountered this and has a fix. My shifter is occasionally hard to shift and sometimes gets stuck in drive and its extremely hard to shift is to 1 2 or 3. It is not a trans issue because I have the shifter out of the car and it does it on the bench. The issue is in the assembly itself. Any insight will help thank you
Old Jun 18, 2024 | 04:24 PM
Chris Scott's Avatar
Chris Scott
So the plastic bushing on the linkage isn't broken/cracked?
