h/c LS7 vs Boosted LS3
Old Jun 25, 2024 | 03:37 AM
northernn's Avatar
northernn
2nd Gear
Default h/c LS7 vs Boosted LS3
Hello all!
I’m a close relative of y’all from the 5th gen camaro forum. Here to ask a question i could not find an answer for on the internet!
What is better for drag racing / roll racing?
a nasty h/c LS7 (c6 z06) setup or a boosted (c6 gs / base) setup?
Im referring to straight line speed, not auto cross or track events. With occasional daily driving between.
Every other forum post is referring to either n/a vs n/a built or a boosted vs boosted build. Everyone knows LS7s can’t handle much more than 6lbs of boost but a LS3 can eat it up all day.
I already own an LS3 6MT in my 5th gen. I really don’t wanna build another h/c na car unless it’s the almighty LS7. On top of that, if i build another LS3 it will be boosted.
Grand sport C6s seem to only be floating $5-10k cheaper than Z06s in my area (Toronto Ontario).
Z06s are floating around $48-55k CAD ~ T56 not TR6060 models.
Let’s hear your opinions!
Old Jun 25, 2024 | 07:54 AM
Orion2011's Avatar
Orion2011
Boosted LS7....
Old Jun 26, 2024 | 01:45 AM
northernn's Avatar
northernn
2nd Gear
Originally Posted by Orion2011
Boosted LS7....
cylinder walls are too thin to run any sort of boost
Old Jun 26, 2024 | 05:22 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
naaaa plenty of people have been boosting LS7s for years, just gotta do it the right way. Just comes down to how deep in your pocket you want to go. Personally the boosted LS3 is probably the better bang for your buck but a 600hp h/c/i ls7 is pretty skitz too.
Old Jun 26, 2024 | 08:05 AM
old motorhead's Avatar
old motorhead
A lot of the LS7's popularity comes from what's around it in a C6. The Z06 is lighter and better balanced than any other C6. Hundreds of pounds difference between a Z (lightest C6) and a Grand Sport with an auto transmission (heaviest C6).
In a Camaro, I'd go LS3 with a TVS blower. Helps that the LS3 is already in your engine bay. Magnuson Heartbeat would be my top choice. With 10 PSI, mild blower cam, and bolt ons, it will out power/torque a heads and cam LS7 from bottom to top. It will live a long time without any issues either. You don't have to do much research to find a **** load of horror stories due to LS7 head issues. They have issues even after they've been "fixed". I love to drive Vettes. Absolutely hate to repair them.
Old Jun 26, 2024 | 04:17 PM
Dano523's Avatar
Dano523
Boosted LS7....
Nope, since stock LS7 block can not take a lot of pressure (only about 7lbs of boost), since very this cylinder liner spots between the cylinders.
Simply, can make more power out of a boosted LS3, since cylinder liners are thicker between each other.
As for boosted LS3 motors with centrifugal super charger, over 700hp, and now have to trying to keep all the power going down to the tarmac, without just roasting street tires; so next hurdle you will need to over come on the streets.
As for HPDE road course use, then LS7 any day of the week, since it not a HP thing, but a torque thing that is much more manageable on hard drives out of the apex with that motor instead.
Old Jun 26, 2024 | 06:33 PM
grinder11's Avatar
grinder11
You guys should try looking up Thomson Automotive (now LPE) builds a 1,000 hp LS7. Its out there online, built around 2014, and in a Motor Trend article. It made 1,000hp reliable hp with the LS9 blower. It also cost $40,000 in 2014 $$!!!
Old Jun 26, 2024 | 08:04 PM
slowtealz28's Avatar
slowtealz28
A 600+ wheel C6Z with a good drive is a tough matchup for a stock bott end LS3 with boost. They’re lighter and can turn a bit more RPM. It would probably take 800+ wheel boosted LS3 to keep up with or possibly beat a 600+ C6Z
Old Jun 27, 2024 | 12:39 AM
taylori497's Avatar
taylori497
The access to lighter weight of the Z really matters in this scenario. It's pretty easy to get a Z down to sub 3k with a driver. That being said, a 600+ NA LS7 that's light as can be isn't the most fun thing to cruise around in for normal driving. While a boosted LS3 can make 800 and cruise around kinda normal with all the amenities. A friend of mine and I have this exact scenario, he isn't going to get groceries or doing a road trip in his NA car that weighs close to 2800 with him in it. While my TT LS3 car I drive all the time and love taking it everywhere, still has the AC.
Personal opinion but unless you're specifically going for some class or something, NA LS builds are a lot of money for less.
Old Jun 27, 2024 | 02:58 AM
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
I'd take a boosted GS over a h/c/I Z.
Old Jun 27, 2024 | 07:02 AM
old motorhead
Aren't we talking about a gen 5 Camaro here? The OP also said this: "Im referring to straight line speed, not auto cross or track events. With occasional daily driving between."
The weight difference will be the weight that the supercharger system adds minus the parts it replaces. Less than a hundred pounds. It won't take two hundred hp to make up for that. It won't take 50 hp to make up for that if a TVS blower is used. A 650 wheel hp TVS rig will outpower and out torque a 600 hp n/a LS7 from idle to redline. The torque difference is hugely in favor of the TVS blown LS3. Full boost coming in just past idle makes a big difference.
Old Jun 27, 2024 | 07:07 AM
furious427's Avatar
furious427
LS7 is king!
Old Jun 28, 2024 | 11:17 PM
Ur2slow90's Avatar
Ur2slow90
Cruising
Just went through this scenario. It came down to drive ability of an auto with an E-force making 630 whp, very stock like when you want it and little to no traction in boost.
Old Jun 28, 2024 | 11:36 PM
tektrans's Avatar
tektrans
If the N/A LS7 had an auto behind it with the right converter/ gears/ tires I'd choose that over a boosted stock LS3 but you have to row the gears on a zo6.
imo to have any N/A set up for the track if needs the right parts behind it and on our cars that can get expensive really quickly. A centri blower will be easier on the driveline out of the gate.
Old Jun 29, 2024 | 11:03 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
That's exactly the setup I have in my drag car and I've never been outrun by a boosted LS2 or LS3.
Old Jun 30, 2024 | 05:02 PM
tektrans's Avatar
tektrans
Case in point, Bad *** brother!
I had an LS7 (441) in my '98 Trans Am-Rossler, Moser, Neal Chance etc 9.6x all day long 1.29 60'
Gotta have the right parts in an N/A car-ALL the right parts. You have yours leaving hard!! Nice job.
Old Jun 30, 2024 | 06:13 PM
da6speed's Avatar
da6speed
You've never ran a boosted C6 that was setup correctly then. Back when my car was a blower car, I could run the 1/8th, let off and coast to some 9 sec passes lol.
To h/c LS7 vs Boosted LS3
Old Jun 30, 2024 | 06:59 PM
Eshoremd's Avatar
Eshoremd
Saying "boosted" could mean 6lbs of boost, could mean 26lbs of boost. Little bit of a difference.
Old Jun 30, 2024 | 09:54 PM
tektrans's Avatar
tektrans
I’m sure he meant similar HP set ups being that the OP was contemplating a h/c LS7 or a boosted GS.
Old Jul 1, 2024 | 05:59 PM
Dzv69's Avatar
Dzv69
OMG this is Badd Azz !!!!
