Front Cradle Bolts or Nuts??
I'm in the process of pulling my rack to replace the balancer and got to the part where I need to lower the front cradle a tad to get the rack out. I've read the horror stories about impact damaging things if used on these bolts. I went to loosen mine this evening and it looks like the nut is not spinning on the bolt (as if this was a bolt treading into the frame). Just having a bit of a panic that the only 2 bolts that I broke loose with a ratchet the nut is siezed to the bolt and the bolt is now messed up. Didn't feel like a bolt stretching/yeilding. When I didn't notice the nut moving I tightened the nut/bolt back and it did tighten. Am I just being paranoid? I stopped for the night fearing the $$$$ that I just stumbled into.
TLDR: is the nut on the bottom of the cradle a nut that should be loosening off the threaded bolt, or should the whole thing be spinning as an assembly?
On the steel-framed cars, the bolt head fits into a recess that keeps it from spinning. On the aluminum-framed cars, the bolt head has a tab that's secured with another screw.
If these features are buggered up you'll need to put a tool on the bolt head it to prevent it spinning while you undo the nut.
