Service active handling and traction control system help
Just changed my oil and drove the corvette about 15 miles and now I get Service active handling system and service traction system. What could this be?
supposed to leaving for the Dragons Tail trip on Wednesday. I need help
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
If it clears when you turn the car off and then back on again, check all of the wheel speed sensor connectors.
They are very sensitive to getting bumped around so make sure they are held tightly to each hub. It also helps to disconnect and reconnect each one too.
You should check for any stored trouble codes…if you don’t have a scan tool that can read DTC’s from all modules an auto parts store may read them for you.
