C6 Plastic Coolant Surge Tank Longevity.
Old Jul 21, 2024 | 06:56 PM
Corvettta's Avatar
Corvettta
Default C6 Plastic Coolant Surge Tank Longevity.
Hello. I’m wondering about the longevity of the plastic coolant reservoir expansion tank on a 2007 C6 with 120000 miles.
would it be wise to replace it ? I’m always wary of plastics longevity in heat for 16 years.
Old Jul 21, 2024 | 07:05 PM
Spaceme1117's Avatar
Spaceme1117
I have a 2011 GS and I replaced mine recently. 45K on the clock. Mine was a bit yellowed and had some staining on the inside. Made it a bit difficult to see the coolant level.
It's pretty cheap so might as well replace it.
Old Jul 21, 2024 | 07:17 PM
Corvettta's Avatar
Corvettta
Thanks for the response. Where would you buy one to ensure it’s not a Chinese knockoff and also speaking of Chinese knockoffs where would you but the block coolant drain plug on the right side just above the starter?
Old Jul 21, 2024 | 07:28 PM
Spaceme1117
I purchased a genuine GM tank from RockAuto: https://www.rockauto.com/en/moreinfo...=10457&jsn=559
For the block drain plug, ICT Billet sells them:
Amazon Amazon
Old Jul 21, 2024 | 09:01 PM
Aardwolf's Avatar
Aardwolf
Kinda tough to say hmm maybe three hundred years. It's not getting UV so how long does that type of plastic last?
Old Jul 22, 2024 | 02:14 PM
Corvettta's Avatar
Corvettta
Back to the block drain plugs, mine had a steel plug on the left side . The torque is 50 nm.
All new ones have brass plug.
Same torque?
I wonder why the change.
Old Jul 23, 2024 | 02:22 PM
bynummustang's Avatar
bynummustang
Same torque?
My guess is why would you want to use a harder metal (steel) when threading into the block if you're not looking for clamping force. Block plugs need to seal liquid. Brass being soft is good for this use case.
Old Jul 23, 2024 | 02:57 PM
Corvettta's Avatar
Corvettta
Is the torque the same? 50nm?
Old Jul 23, 2024 | 08:17 PM
bynummustang
Would assume so but don't know. Seems like a ton of random fasteners are 37 ft-lb (50 Nm)
To C6 Plastic Coolant Surge Tank Longevity.
