408 stroker build help
Old Jul 22, 2024 | 08:09 AM
noe3433's Avatar
noe3433
1st Gear
Default 408 stroker build help
doing a 408 stroker for my ls3 Camaro 2015 i needed help deciding which stroker kit to get summit racing pro 408 stroker 9:8:1 or there 408 11:1:1 its gonna be NA for a while until I decide to do boost. my setup is
Holley hi ram with 1 inch spacer and sheet metal lid 102MM throttle body and a velocity stack right off it.
I need help with which heads to go with I wanna do rectangular port.
7/8 long tube headers and 3 inch dumps out the rear
have ZL1 pump and ZL1 injectors not sure if they are enough.
and I also need help with which cam to go with.
this car will be mainly used for roll racing.
will also be on E85 most of the time.
would also like to have a rough estimate of horsepower expectations .
