Okay guys I have a 2007 C6 with the LS2 (automatic) and 90k miles on it in my vette cart/drift buggy. One of the guys in my shop is about to build an LS3 in a 2011 C6 with 80k on it and will be pulling the heads/intake as he is doing new heads/hiram/cam/etc. on this build so I was going to swap the LS3 heads/intake onto my LS2. I've got a custom car shop but I am more a cosmetic/suspension/interior/upfitter and definitely not an engine builder so I want to make sure I get everything I need and refresh anything needed.
Here's the plan:
LS3 Heads/Manifold (was not going to port them as I am not pushing for crazy HP but if there are flow issues and recommended can have it done)
Mild cam (recommendations?)
Ported LS3 throttle body
Headers
And then have my tuner retune it after
Anything else needed other than heads/intake/throttle body to work on my LS2 C6?
Are the throttle body connections the same for LS2/LS3 or do I need a wiring adapter?
Anything else recommended to replace while doing all this? Oil pump?
I think I'm wasting my breath here, but I'll throw this out for posterity's sake. If you put stock LS3 heads on an LS2 with an itty bitty cam, you're wasting your time and money. Your static CR is going down...by quite a bit. You're losing power, fuel eco, and drivability right there. A cam not specced specifically for this change exasperates this. You're better off porting your stock heads, adding a FAST intake manifold, along with the itty bitty cam. WAY better use of funds.
Just to be clear, I'm not a fan of big cams on street Vettes. Far from it.
I have Texas Speed stage 4 cam (F-35). At first I had the stock ls2 heads and switched them out with stock Ls3 heads. Holy ****. The mid to high range is ridiculous now. I feel for certain I picked up an entire second in the quarter. That’s with the lower compression as I didn’t shave them at all. Planning to stroke engine and shave heads for additional HP.
I was thinking of doing the cam thing since I've already added long tube headers and a Air Raid intake system.
I'm interested in hearing why you don't like camed street cars.
Tom
I love cammed street cars. My 2013 is a heads/cam car. I hate big/high overlap cams that ruin two of the attributes I like about Vettes. I like smooth, efficient, and quick. While big overlap cams make the juice...no doubt, they take away the smooth and efficient though. That's unacceptable to me. Some guys like that. I don't. At all.
Some say a really good tuner can tune out all of those bad attributes of a big cam. That hasn't been my experience at all. Just imagine how good your Vette can run with a more moderate cam tuned by that same genius tuner.
The big nasty cams lose power on the streets in the rpm band that you actually use and only show increases above 5500 rpm vs a more moderate cam. Again, some may like that. Just ain't for me.
You can go too small on a cam swap also. What's the point? Cam swaps are expensive, especially if you hire everything done. Add all the other things to make your LS powered Vette a fun street ride and then choke it with a 220 and under cam just doesn't make sense to me.
Here's the plan:
Headers
You will need new head gaskets. I would go with factory GM LS3 MLS gaskets.
You will also need a set of valve springs to go with that cam. Cam Motion's .625 lift beehive springs would be excellent.
I recommend replacing your valve seals when you swap out the springs. They are cheap and very easy to change out.
You should also change out your cam retainer plate. It is a cheap part and will ensure that you have good oil pressure.
If your engine has good oil pressure now, no need to change out the pump.
With 90K on your engine, you could put in a new set of lifters with the cam. Factory LS7 lifters or even some Chevy race or "Caddy" lifters would be excellent. Make sure to put in new lifter trays. If you want to go all out, a set of Johnson link bare lifters would be awesome but they are not cheap.
Substitute a 224/230 115+4 .610/.610 for the cam I used. That build has been going strong for 5 years or so. Little bit of a rough idle, but perfect manners. Runs really strong too.
I didn't feel any loss of power in the lower rpm. I think it's because the Ls3 intake flows better at all rpm levels vs Ls2 intake. But I understand why many don't like a big nasty screamy cam. Just like some guys don't like big ****.....
I do agree that the LS3 intake mani is a big step up from the LS2 intake. Port and rod mod it and it's another level of better. The bigger cams I've been around were basically dead below 3500 rpm vs a well specced more moderate cam. I haven't had every cam there is to be had, but I've had enough to know what makes me happy and how to get there. As far as **** go....I haven't experienced them all, but I tend to like them all.
