Tranny not downshifting??
Old Jul 31, 2024 | 11:16 AM
dgrimes22's Avatar
dgrimes22
Default Tranny not downshifting??
2013 C6 with A6 tranny. Been running great but recently after highway driving, stopped at redlight and car would barely move forward. Seemed to be lugging. I pulled over, Put in neutral, shut it down, restarted and it took off like a bullet. Has not done it since then, but it felt like it was in a high gear. Any thoughts??
Old Jul 31, 2024 | 11:34 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Start by putting a scan tool on the car that can scan all modules…if you don’t have one your friendly auto parts store may be able to do it.
Old Jul 31, 2024 | 12:16 PM
dgrimes22's Avatar
dgrimes22
Yep i have OBD2 scanner, showed no codes. Also just to be sure went to local parts store, and same results.
Old Jul 31, 2024 | 12:55 PM
C5 Diag's Avatar
C5 Diag
Well if no DTC’s may be a little difficult to diagnose…I’d look at some live data with your scan tool and look at TCM, ABS, and Throttle Body data.
Old Jul 31, 2024 | 02:31 PM
dgrimes22's Avatar
dgrimes22
C5 Diag, excuse my lack of expertise on OBD2.. Maybe my scan tool is not the best, but i'm not sure where to go to find the data you mentioned. My scanner is AUTOPHIX 126P
https://www.autophix.com/product/om126p
In the manual, under DTC example, under "subsystems", it mentions transmission controls. I am not sure what look for here.
Old Jul 31, 2024 | 02:39 PM
C5 Diag's Avatar
C5 Diag
NO !!…that’s OK !!…I looked and you basically have a “code reader”…a factory level scan tool is what’s needed to be able to view those modules I mentioned…in each module you can view many data PIDS to help with a diagnosis….usually these code readers can only view “P” or Powertrain codes…can you view “C” and “B” codes and look at this live data ??…most owners of these code readers only use them to look at and erase codes…a friend of mine owns an AAMCO transmission shop…I’ll try to bounce this off him…I don’t do a lot of transmission work.
To Tranny not downshifting??
