Electric problems
Old Aug 2, 2024 | 10:41 AM
jimsvet2's Avatar
jimsvet2
6th Gear
Default Electric problems
In the past year I purchased the "dreaded 2005" corvette convertible. I was unaware of the issues with that model. I have gotten several items taken care of but am once again unable to start the care due to electrical issues.
Start button does not light up, when pressed it doesn't do anything.
Battery is fully charged.
Electronic door locks to open door do not work
After market radio installed by previous owner does not shut off and may be part of the problem.
Clicked behind the seats appears to be a relay but not sure
Any suggestions on what I can look for.
Old Aug 2, 2024 | 11:25 AM
vinny R's Avatar
vinny R
You may want to start with the ignition switch/button. Just a guess but when I bought my 09 I had similar issues, no green light and especially the radio doing weird things. The switch powers a bunch of accessories. I replaced it, it was only $55, and those issues went away and haven't returned.
Old Aug 2, 2024 | 04:02 PM
madsonp's Avatar
madsonp
Check the battery in your fob, should be reading 3.3VDC if it’s a fresh battery.
Old Aug 2, 2024 | 05:28 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Start button does not light up, when pressed it doesn't do anything. Battery is fully charged. Electronic door locks to open door do not work After market radio installed by previous owner does not shut off and may be part of the problem. Clicked behind the seats appears to be a relay but not sure Any suggestions on what I can look for.
I had a 'dreaded 2005 Corvette convertible for 3 years and 40k miles. No problems, ever.
If you have the stock radio, etc, I suggest putting everything back to stock and see where you are. It certainly could be in the ECM but eliminate funky wiring (or at least verify the wiring) first.
Old Aug 2, 2024 | 08:21 PM
540 vette's Avatar
540 vette
I have a dreaded 2005 and the only electrical problem I had was my fault. I forgot to leave it in reverse and it died.
Why is it dreaded.
Old Aug 2, 2024 | 08:34 PM
MintChip's Avatar
MintChip
I have the “dreaded” 05, and it died on me due to me leaving the glovebox open for a couple days (which has a light in it). I’ve since replaced the battery and remember to shut the glove box (and put in R) before shutting her down. Shes been good to me since. I’d suggest going back to the factory radio. Best of luck.
Old Aug 2, 2024 | 10:08 PM
rbwinston's Avatar
rbwinston
I too have the "dreaded '05" which I love. Never any electrical issues. You don't say if the battery is loosing charge or not. As suggested check fob batteries. I would absolutely not rush to replace the radio as I highly suspect it's NOT your problem. If it doesn't shut off when you turn off the car off then it's not wired correctly but that should be an easy fix, just need to be sure it's wired to a switched source not a hot all the time source. How old is your battery?? Do you keep it on a tender??
Old Aug 4, 2024 | 10:55 AM
jimsvet2's Avatar
jimsvet2
6th Gear
Vinny
Vinny R
Thank you for your suggestion.
Is the part you replaced the one on the dashboard or the one on the started motor?
I ordered, and will have tomorrow, the one on the dashboard. I hope to be able to install that soon. Did you replace it yourself, and if so, was it very complicated.
Madsonp
I did check the fob battery and it is good. Thank you for your suggestion
540 vette
My son and I have begun the process of looking into the wiring, not completed as yet. There are a couple of after market items, the radio being one, and a lighted windscreen that changes colors. It could be the relay for one or both of those. This is definitely a work in process.
Old Aug 4, 2024 | 10:58 AM
jimsvet2's Avatar
jimsvet2
6th Gear
Yes, it was losing charge and we discovered that the light in the glove box was not turning off. We took care of that but now it is starting to have issues again.
Will be working on the wiring soon with my son.
Old Aug 4, 2024 | 11:03 AM
jimsvet2's Avatar
jimsvet2
6th Gear
Default jimsvet2
Forgot to say, the battery is new and no I wasn't keeping it on a tender after we seemed to have it fixed.
Old Aug 5, 2024 | 09:49 AM
vinny R's Avatar
vinny R
Vinny
Vinny R
Madsonp
540 vette
It was the dash one. The push button. It was not that hard, about an little less than an hr. I watched a short youtube video on which interior panels to remove.
Old Aug 10, 2024 | 12:18 PM
jimsvet2's Avatar
jimsvet2
6th Gear
Default Fixed one thing now another
Last week I noted an electrical problem and received some good advice.
I did replace the starter in my 2005 Corvette convertible, The battery in the keyfob was also replaced and the battery for the vehicle is new and has a full charge.
I now can start the car again and the strange clicking sound behind the seats has been silenced.
The top was down on the car and since I could not get pretty much anything electrically operated to work could not check on the top. When I tried the last couple of days with seemingly everything else in good shape, I could not get the top to even move. The button on the dash in the lower left to put the top down or up does not do a thing.
Anyone who has had this problem?
Please advise!
Jim M
Old Nov 13, 2024 | 12:03 PM
jimsvet2's Avatar
jimsvet2
6th Gear
I have had a lot of work done on my 2005 Corvette and many things were repaired or replaced.
I STILL have an electrical issue though. Car has been running fine. Drove to the gym this morning and as I pulled in the parking lot it died...AGAIN! Upon further investigation, one of the cables had melted, this happened before with a bad battery. New battery was installed and new cables as well. so what is causing this now?
Would appreciate anyone else providing some information. About at the end of my rope with this car. Can't even sell it because I don't want to pass on this mysterious mess.
Old Nov 13, 2024 | 12:18 PM
ruxvette's Avatar
ruxvette
...When I tried the last couple of days with seemingly everything else in good shape, I could not get the top to even move. The button on the dash in the lower left to put the top down or up does not do a thing. Jim M
There is a 'bulkhead in the trunk so stuff doesn't get into the top mechanism. If it is not latched in place the top will not operate.
Old Nov 13, 2024 | 12:22 PM
ruxvette's Avatar
ruxvette
...one of the cables had melted, this happened before with a bad battery...
Which cable, + or - ? Have you checked the starter solenoid for broken/crusty connections? Try to find a wiring diagram and check that all the grounds are clean and tight.
Old Nov 14, 2024 | 01:30 PM
kestell123's Avatar
kestell123
If you could post a pic of what melted that would help . Also after haveing the battery disconected the windows must be reindexted for the top to work.
Old Nov 14, 2024 | 03:22 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What cable ????????
To Electric problems
