squeaking
Old Aug 8, 2024 | 05:34 PM
jnichols's Avatar
jnichols
Default squeaking
Recently I went on an hour drive and when I was coming off the highway I hear like squeaking sorta, not when I turn or brake but when I coast under 60 mph it’s like something is rubbing. My best guess is a sway bar endlink I jacked it up sprayed PB Blaster (WD-40) on all the joints but maybe should’ve driven it a while after I don’t know just looking for an answer to this noise
File Type: mov
Old Aug 8, 2024 | 07:36 PM
HK770's Avatar
HK770
I'd be looking at the springs and shocks. There looks to be way to much body movement.
Old Aug 8, 2024 | 08:34 PM
jnichols's Avatar
jnichols
should I just throw some grease on them or what
Old Aug 9, 2024 | 10:53 PM
HK770's Avatar
HK770
There are no grease " Fittings" ports on either shocks.
Just by the movement in body, I'd wonder if the shocks are there.
And if they are thee I believe It's time to replace them. Look at the rubber mounts.
I would look at the springs and at the rubber end mounts
Just my .02
Old Aug 10, 2024 | 12:11 AM
jnichols's Avatar
jnichols
Just my .02
I think it may just have the struts I’m not 100% if I saw the spring while I was under there I was spraying PB blaster on all bolts and rubber it helped the noise for a couple miles but it’s itching to come back. Also in the video I was pushing really hard to get the sound as loud as possible
Old Aug 10, 2024 | 12:29 AM
HK770's Avatar
HK770
The spring is a flat bar of fiberglass 5" -6 " wide, running left to right in both front and rear of car between tires
Cars from factory came equipped with shocks what your naming as struts
Luck HK
To squeaking
