Front passenger shock removal
Old Aug 24, 2024 | 09:48 AM
bwill03z's Avatar
bwill03z
Default Front passenger shock removal
I’m changing out my factory shocks for some Bilsteins. I’ve got the rears done and will be doing the fronts this afternoon and was wondering what is the best way to get that top nut off on the passenger side? I have the Lisle tool but there’s just not much room at all to work there because of the fuse box and the ac sensor. Can you just unbolt the fuse box and move it? Even with the Lisle tool I didn’t have enough room to get a wrench on it. Thanks
Old Aug 24, 2024 | 04:44 PM
jamieo's Avatar
jamieo
Do you plan on keeping the old shocks?If not,just cut the top sleeve off and hold the shaft with vice grips.sometimes the old nuts on the top can be stubborn to remove.
Old Aug 24, 2024 | 04:49 PM
bwill03z's Avatar
bwill03z
No I don’t, so yep that’s what I’ll do. Thanks man
Old Aug 24, 2024 | 05:31 PM
jamieo's Avatar
jamieo
No problem
To Front passenger shock removal
