ACDelco 41-985
Old Sep 1, 2024 | 08:06 PM
Sayfoo's Avatar
Sayfoo
Default ACDelco 41-985
Fairly new to me "09 Vert, stock ls3, with 55K miles.
The car runs fine, but while fiddling around, I thought I would pull a plug.
ACDelco 41-985. Gap was .087. Searching the forums, it looks like the little tip is gone, hence the .087 gap. Also, it looks like the 985 is for a ls2 or ?????
Also, searching the forums I see a few different #'s for oem plugs. 41-104, 41-110,41-162, etc.
Rock auto lists 41-162 pre gapped at .040 as stock.
So, is the 41-162 the correct oem iridium?
Old Sep 1, 2024 | 10:14 PM
jamieo's Avatar
jamieo
41-985 should be the original plug number.It has been superceded by 41-110 and then the 41-162.The 41-104 is a colder plug used in the LS7 and LS9.
Old Sep 2, 2024 | 12:31 PM
Sayfoo's Avatar
Sayfoo
Interesting to hear that the 41-985 were the OEM's. My research showed them to be multi model use, even 5.7 trucks.
Since the 1 I removed was missing the tip and had a .087 gap, I'm going to buy new ones. Rock Auto and AZ both list 41-162 as correct, so I ordered these from RA.
It really surprises me that 1, or more, damaged plugs wouldn't cause a misfire code. And, if not, will the new plugs make it run better?
Old Sep 2, 2024 | 02:46 PM
jamieo's Avatar
jamieo
You will gain any power you have lost from the bad plugs but it should be alot smoother.
Old Sep 2, 2024 | 05:49 PM
87gtNOS's Avatar
87gtNOS
41-985 was the original plug and it had a little puck of platinum on the center electrode, that would fall off, hence the mile wide gap.
41-162 is an iridium Delco plug
41-962 is the replacement platinum for the 41-985.
Either 162 or 962 will be fine....I would use the 41-162 if it was mine.
Old Sep 2, 2024 | 07:33 PM
Sayfoo's Avatar
Sayfoo
For something as simple as a spark plug, GM sure makes is difficult.
To ACDelco 41-985
