Service Active Handling System
Old Sep 14, 2024 | 11:18 AM
agsus22's Avatar
agsus22
Default Service Active Handling System
Our 2005 Corvette keeps having an inadvertent “Service Active Handling System” light come on in the DIC, and the traction control light lights up in the dash. It seems to be when we turn the wheel sharp to the right to pull into or back out of a parking spot. Turning the car off and back on makes the light go away. What do you suggest we check? Thanks!
Old Sep 14, 2024 | 11:26 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Check for trouble codes with a scan tool and NOT a “code reader” which only reads Powerplant codes.
Old Sep 14, 2024 | 12:37 PM
Sayfoo's Avatar
Sayfoo
Most of the parts store will do a code scan for free.
Your problem could be anything from a frayed wire, bad spark plugs, bad injector, abs module, etc. There have been numerous threads here recently about such problems. I did one yesterday.
To Service Active Handling System
