Traction Control System Active
Old Sep 14, 2024 | 10:49 PM
Connocclar's Avatar
Connocclar
2nd Gear
Default Traction Control System Active
2007 base, put on new wheels and tires today. 305/35R19 rear and 265/45R18 front. All of the calculators I've used say they have the exact same diameter. Whenever I get up to ~70 mph the traction control active message will pop up on the display. Looking for help figuring out the cause. I assumed the tires were spinning at different speeds but with the exact same diameter they should be same speed. There is no check engine light.
Old Sep 14, 2024 | 11:56 PM
jamieo's Avatar
jamieo
Tires need to be staggered,not the same diameter.That is the issue.
Old Sep 15, 2024 | 01:09 AM
Connocclar's Avatar
Connocclar
2nd Gear
Do you know where I can find that info written?
Old Sep 15, 2024 | 02:10 AM
jamieo's Avatar
jamieo
In countless posts on the forum.I think a 4% difference is what the ebcm is happy with.A 265/40 would make it work.
Old Sep 15, 2024 | 09:02 AM
torquetube's Avatar
torquetube
Look at your door jamb. The stock sizes are printed there. Calculate the diameters. The rears are about 1.2" larger than the fronts, or about 104%.
To Traction Control System Active
