2006 base bcm help
Old Oct 9, 2024 | 12:35 PM
ls2duck's Avatar
ls2duck
Navigator
Default 2006 base bcm help
Hi, I have a 2006 corvette coupe with a bad bcm that I have to swap it out. I recently found one up for sale however it is for a convertible instead of a coupe but all other features match mine. Was wondering if it matters whether swapping the convertible's bcm would work? Thanks in advance.
Old Oct 9, 2024 | 05:58 PM
JackDidley's Avatar
JackDidley
Maybe Trog can help.
https://www.corvetteforum.com/forums...cm-repair.html
Old Oct 9, 2024 | 10:23 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Compare the part numbers. If the same, no problem.
Old Oct 9, 2024 | 10:53 PM
ls2duck's Avatar
ls2duck
Navigator
looks like the part numbers match up thank you boss
Old Oct 12, 2024 | 08:09 AM
Dano523's Avatar
Dano523
Will still need to be SPS flashed, so it learns the security code number for that vin number, and can comnicate with the rest of the modules locked to same secuirty code number.
As for one SPS flashed to vin, then use tech II to go into BCM set up, to make sure that is selected in the RPO list, matches what is on the car. Hence car may have come without hud, added later and since BCM is being flash to vin of how it came from the factory, would need to select HUD in the BCM set up RPO list in the end for hud to work.
To 2006 base bcm help
