C6 Gas pedal
Old Oct 21, 2024 | 02:40 PM
Ed1801's Avatar
Ed1801
Default C6 Gas pedal
Is the gas pedal supposed to be like this? Really don’t like how it feels. Excuse the messy floor 😃
File Type: mov
Old Oct 21, 2024 | 06:56 PM
davidfarmer's Avatar
davidfarmer
what's the problem? With you heal on the floor you don't notice the articulation.
Old Oct 22, 2024 | 06:16 AM
Spaceme1117's Avatar
Spaceme1117
Normal. The gas pedal is on a rod and has a pivot.
Old Oct 22, 2024 | 12:37 PM
gdmoore01's Avatar
gdmoore01
The pedal is electronic and connected with a plug-in harness. The pedal resistance is provided by a spring, that may be broken in your application. You can disconnect the plug and pull the pedal to check for any problems and replace it if needed. Otherwise, you would need to get used to it.
GD
To C6 Gas pedal
