Airbag light
I have continuity in the wiring when checking by color from the pink and grey airbag connectors down to their respective wires at the airbag harness clip under the wheel. I also have continuity when testing between the connectors by this method (
The airbag harness is clipped in securely below the wheel, the pink and grey airbag connectors snap into the airbag, and the yellow CPA clips snap in as well (they are full length). Each of these seems to be a unidirectional clip in part.
I can start the car, clear the code, and it recurs immediately. The code is "Driver steering wheel air bag deployment loop low resistance."
Am I missing something? Does anyone have clarifying input or direction on a next step? Thank you.
I have continuity in the wiring when checking by color from the pink and grey airbag connectors down to their respective wires at the airbag harness clip under the wheel. I also have continuity when testing between the connectors by this method (https://www.youtube.com/watch?v=-UgL22uM8Tk). I believe that should mean the clock spring wiring is intact. The horn works.
I did as you suggested and pushed the CPAs in a little more after the plastic pieces clicked. The problem resolved. It is hard for me to imagine that the repair was that simple or that they would need a little snugging once already clicked, but it worked. Thank you.
I appreciate your help.
