Flex-fuel kit
Old Dec 1, 2024 | 12:16 PM
enb98's Avatar
enb98
Default Flex-fuel kit
I have an '05, It has built heads and big cam installed from previous owner. I want to add a flexfuel sensor to gain some more power. What should I get and its it something I can do or do I need to go to a shop?
Old Dec 1, 2024 | 12:40 PM
Travlee's Avatar
Travlee
You can install it and pin it out to ecu, but a tuner will need to activate it in the ecu
Old Dec 1, 2024 | 02:34 PM
Aardwolf's Avatar
Aardwolf
Yes as above. If you go the DSX kit they will enable it in a tune but you would need hp tuners to write it. Also not mentioned did you increase the fuel pump? I have the DSX kit on my '05 and at near stock hp the fuel pump can't keep up with e85.
Old Dec 2, 2024 | 06:41 AM
Spaceme1117's Avatar
Spaceme1117
You will likely need a higher capacity fuel pump, larger injectors, a flex fuel sensor/kit, and then a tune. And I don't think the gains are really worth it on a NA LS engine.
To Flex-fuel kit
