Header coating
Old Dec 7, 2024 | 03:37 PM
shutout's Avatar
shutout
Default Header coating
Getting ready to pull the trigger on Kooks headers and catted x pipe. I want to do everything right the first time. Should I get the headers coated or just purchase sparkplug / starter shields and wrap anything else affected by heat?
Old Dec 7, 2024 | 05:30 PM
MARSC6's Avatar
MARSC6
Most don't but the coating really helps with heat.
Old Dec 7, 2024 | 05:45 PM
shutout's Avatar
shutout
I like the reduced temperature that comes with coatings, but it is expensive. Or, is it really even necessary? I have read so many different opinions I'm not sure what to believe.
Old Dec 7, 2024 | 05:52 PM
old motorhead's Avatar
old motorhead
I've owned three C6's. Two supercharged and the current one is heads/cam. All had long tube headers. LG Superpros, Pfadt, and currently Kooks. None were coated. I didn't do any heat shielding of any sort. Stock plug wires. I've never had a heat related problem. I live in a hot climate too. Just lucky I guess.
Old Dec 7, 2024 | 05:53 PM
MARSC6's Avatar
MARSC6
I did the coating just in case.
I have no idea what the cost is now but at the time it wasn't really that much.
Old Dec 7, 2024 | 06:11 PM
shutout's Avatar
shutout
Thanks for the information, guy's.
Old Dec 7, 2024 | 07:47 PM
davidfarmer's Avatar
davidfarmer
wraps do a whole lot more, save your lines and wires, but can fatigue the metal over time as well
Old Dec 8, 2024 | 08:00 AM
Dreamer2's Avatar
Dreamer2
I am considering this mod as well. I definitely want to add heat shielding to the tunnel area. My only C6 complaint has always been cabin heat.
Old Dec 8, 2024 | 09:35 PM
Spaceme1117's Avatar
Spaceme1117
Last time I got a quote from Jet Hot, it was nearly $900 for everything including shipping.
I ended up wrapping my headers in the lava rock based wrap. Used some black silicon spray to coat them and prevent the fibers from going everywhere. That has been about a year and they are holding up nicely.
Should I get another set of headers, I will likely just run them as bare metal.
Old Dec 8, 2024 | 11:10 PM
C6 Motorsports's Avatar
C6 Motorsports
The ceramic coating wears off. I chose to go with titanium wrap instead since I don't drive it much in the rain so not really worried about moisture rotting out the headers. If you paint them before wrapping and then seal the wrap, there shouldn't be any issues with corrosion.
Old Dec 9, 2024 | 07:27 AM
rainmaker gs's Avatar
rainmaker gs
Had my LG long tubes Jet Hot coated (classic finish), they were $800-900; did not coat the X pipe. I'm happy with how they keep engine compartment heat down but they are getting "fuzzy" and I am not happy with that. I did read some of the Jet Hot literature and saw something about polishing them down, or something to that effect. Um, they're in the engine compartment of a C6 Corvette, I can hardly see any of them much less access them to polish them. That would necessitate removal and that won't be happening. Hope the temp protection and coating hold up, but the appearance is degrading and for the cost, I feel it should not.
Old Dec 9, 2024 | 07:35 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I Cerakoted my SE headers and I've done a few sets for other members here on the forums local to me, I can say for a fact it makes a huge difference in heat control. I did before and after reads on the primary's with a laser heat gun and saw almost a 30 degree drop on average. I need to find the time to pull the midpipes and do them as well. Def worth it in my opinion.
Old Dec 10, 2024 | 06:07 AM
shutout's Avatar
shutout
I'll have to look into that, looks like it works well.
Old Dec 15, 2024 | 07:22 PM
baxsom's Avatar
baxsom
I did the jet hot 2000 degree coating before I had mine installed. Only been on a year but still look new
Old Dec 16, 2024 | 08:05 AM
MARSC6's Avatar
MARSC6
The coating I had applied in 2007 is still holding up. A few scratches from removing the headers a few times over the years but they can't be seen when installed.
Old Dec 16, 2024 | 09:03 AM
Dreamer2's Avatar
Dreamer2
I'm in the same boat, analysis paralysis!
To Header coating
